07-20-2010, 04:35 PM | #1 |
stiffening up my sterring
any suggestions out there on stiffening up my sterring.
Mark 1968 C-10 SWB 307/munci 4spd/411possi 1986-1990 1972 Cheyenne-10 LWB 350/TH350 IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER U. S. Navy Seabee "CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard" |
07-20-2010, 04:48 PM | #2 |
Re: stiffening up my sterring
do you have play in the steering? there "may" be an adjustment to limit play but more likely it could be a tie-rod that needs replacing.
07-20-2010, 04:56 PM | #3 |
The steering is loose because it has some warn out parts. Get under there and try to find the looseness. Have someone turn the steering wheel a little (with engine off) and see the areas that have play. Specific areas to look at include the ball joints, tie rod ends, pitman and idler arms, A arms, steering box. If you can't do it take it to an alignment shop and have them evaluate it. Only a few bucks to let you know what's wrong and you can decide what you can comfortably do and what you need a pro for and when. Many of these old trucks have not had the best of lives and are in need for some R&R. Probably just the normal stuff like tie rod ends and idler arm. Also a good front end alignment can make these truck track right and reduce the wandering effect often associated with warn out parts.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-20-2010, 05:59 PM | #4 |
I just replaced my Steering Rag Joint or Coupling and it is stiffer now. Good Luck on your troubleshooting.
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
07-20-2010, 09:02 PM | #5 |
sorry i didnt specify. its not that it has a lot of play in the stering wheel. it turns really easy.
07-20-2010, 09:55 PM | #6 |
If you want it stiffer go back to manual steering. A few times parking in a tight spot in 100 degree weather you will be reinstalling your P/S stuff.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
07-20-2010, 09:58 PM | #7 |
Then how about an off-road steering shock absorber? When I bought my 68 it had one from Rancho on it.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
07-20-2010, 09:59 PM | #8 |
i dont want it that stiff.
07-20-2010, 11:11 PM | #9 |
Various late model steering boxes required more effort to turn, but there were changes in input shaft diameter, turns lock to lock, internal parts that impact turn radius, and the hydraulic fittings.
My guess is that a car box is is externally the same as a 2x4 truck box but you'll need to check. The box from some years of Grand Cherokee are known to be a bolt in for Chevelles. You can buy a new box that's set up right from various places, but they aren't cheap. If you don't want to spend a bunch of money, it may be time to start searching the internet for options. |
