02-19-2003, 06:58 PM | #1 |
which direction for the crossmember?
Putting a bbc in a '67 swb fleetside that was a small block a/t truck. I need to know which direction the crossmember faces. I am using one out of a '71 with Th400. One side of the crossmember has one hole drilled right in the center and the other side has a bunch ( four I think for the e-brake cable mounts)? also when it is on the garage floor (level) one end is higher then the other where the tranny mount goes. If I get it the wrong way it would screw up the driveline phasing. If somebody could look at their trucks crossmember or knows off hand I would appreciate it.
Thanks |
02-19-2003, 07:42 PM | #2 |
Fabricate till you "puke"
The center part , where the trans mount bolts needs to slope down hill to the rear when its mounted in the truck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-19-2003, 07:55 PM | #3 |
Thanks crazyL that makes the most sense.
