Old 07-20-2010, 07:48 PM   #1
57larry
73 front end suspension on a 72
I'm going to rebuild the front suspension on my 72 C-10. I have a complete 73 front end. Any benefit from using the 73 A arms, spindles ect?
57larry is offline   Reply With Quote
Old 07-20-2010, 08:02 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 73 front end suspension on a 72
All the parts are cheaper.
Some like the rubber bushed a-arm bushings that don't need to be greased.
Keith
Convert to disc brakes.
Old 07-21-2010, 12:23 PM   #3
57larry
sounds like I should make the swap then, spindles and all
Old 07-21-2010, 12:47 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
57larry,
just stop by your local auto parts store and have them price out stuff for your 72 and then for a 73-87 setup.....I went to Autozone and there was a $200+ difference.....
I'm going with a 73+ setup when I'm ready!!
Good luck and have fun
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-21-2010, 01:17 PM   #5
Zeke's Garage
Zeke's Garage's Avatar
If you can get the whole crossmember, do the swap that way. It's easier than it sounds, and save for having to drill two holes, and enlarging two more... it bolts right in. I put one in my '70 from an '87 and couldn't be happier.
Zeke's Garage is offline   Reply With Quote
Old 07-21-2010, 01:20 PM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Agree 100%... I did the entire crossmember swap in my shortbox and it was very straightforward.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 07-21-2010, 06:42 PM   #7
57larry
thanks for the replies. I do have the entire front crossmember and will use it then
Old 07-21-2010, 06:43 PM   #8
57larry
when I get the front end aligned, do I use the 73 specs then? thanks
