cracker
emmsions question
my emissions were fine under load, but at idle the hydrocarbons were at 457(ppm), and the max is 400, the CO2 at idle was 2.35 %
when i tuned the carb, under load is still fine, and the CO2 at idle went down to .26%, however, the hydrocarbons went up to 1027(ppm) this is very perplexing to me, and i am wondering what could cause this, and if there is any "easy fix" the truck is running good, the way it is, any help would be apprecited. thanks HJ
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Harry John Albert III located in Phoenix, AZ 1972 GMC JIMMY, 1969 lwb Chevy Frame, 1999 bmw k1200 ltc 1992 Kawasaki concours 1991 bmw k75 1973 cortez motorhome |
You might have gone a bit too lean (slight lean misfire) when you set the idle mixture, try richening it up a bit, just make sure not to go too rich and fail for CO. If that dosent work make sure the idle isnt set too low, make sure all the tune up stuff is OK (plugs,wires,cap and rotor), and if still no luck, check engine compression.
No, Its not a 454 |
"See the U.S.A....."
Try retarding the timing some.(just for the test). then if it passes
advance it to where it was. Also make sure you have fresh oil right before the test and that the engine is nice and warm.
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
cracker
up
Do you have to pass emissions? Like out here in certain counties you don't have to take it(such as counties that have farms) and then there's the county I live in now that makes you E-check, but my '67 would never have to be E-check. Because I think it only goes back to like '80 or something. Is Arizona as bad in emissions as California is?
Brandon |
hjalbert
What exactly did you do to tune the carb? Hydrocarbons(HC) are unburned fuel particles and the number one source of high HC on non computer monitored vehicles is running too RICH, not too lean. Carbon Dioxide(CO2) is a natural byproduct of combustion and low CO2 indicates incomplete and inefficient combustion. What were the values of NO and CO both before and after?
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454 '93 K2500 Suburban, Old 454 (157K) |
cracker
well i do believe i have discovered my problem, i started off today by tuning the carb again, but started by turning them all the way in, then i turned em out about 21/2 turns, ran fine, so i started turning them in, and i tell you i turned them all the way in and the truck still ran, i guess, the carb is just worn out, tommorow i am going to put on a different cabr and go get it tested after i tune that and see where i am at, thanks for all the advice. HJ
14.1 @ 96MPH
That's the same way my truck failed last time through...just had to crank those idle screws in (they were at least two turns too far out each!) and I smoked it.
Just be glad we don't have to get inspected out here. My girlfriend got one hell of a runaround trying to register her Opel GT thanks to the salvage title and the MVD.
Project1970 - LS1 Swap Complete! ![]() |
