07-20-2010, 09:57 PM | #1 |
C10 Club Tennessee
Difference b/t 63-66 and 67-72 Control Arms
I was always under the assumption that there wasn't a difference of these at all, but when I went to look for some bag brackets on suicidedoors I noticed two different types.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
07-21-2010, 01:29 PM | #2 | |
Re: Difference b/t 63-66 and 67-72 Control Arms
The ball joints, sway bar holes, and I think bushing types change 63-66, 67-72, 73-87 |
07-21-2010, 04:02 PM | #3 |
C10 Club Tennessee
thanks ed, I was pretty sure of it
07-22-2010, 12:33 AM | #4 |
60-66 Nut
As far as I know the '63-'72 control arms are the same.....except for sway bar mount holes in the '66-'72 lowers. The control arm bushings changed from steel to rubber in '73 on the C10's. The C20 and C30 retained the steel bushings from '73-'87.
07-22-2010, 01:51 AM | #5 |
If the sway bar holes are different then why was the front bar off of mid 80's 1-Ton a direct bolt in replacement for my original factory front bar on my 65??
07-22-2010, 11:45 PM | #6 |
60-66 Nut
What I meant was that the '63-'72 lowers are the same except that the '66-'72 had sway bar mounting holes in them whereas the '63-'65 did not have the holes. Sorry for the confusion.....
