02-19-2003, 07:34 PM | #1 |
71 GMC Dash? AutoMeter convo.
Who has some pictures of the AutoMeter convert in a 71' GMC dash or matching years? Im putting all AutoMeters in the shop truck
Thanks BADASS
http://www.dfwstangs.net/hosting/BAD.../badasssig.jpg 74' Camaro SBC/TH350 Thats all you need to know. Want some?...Come get some! |
02-19-2003, 09:32 PM | #2 |
I will post some pics of mine tomorrow. They are at the office
02-19-2003, 09:36 PM | #3 |
Ok man thanks
BADASS
02-19-2003, 10:05 PM | #4 |
Car Knocker
here is the one I always liked.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
02-19-2003, 10:13 PM | #5 |
Who makes that?
BADASS
02-19-2003, 10:26 PM | #6 |
Car Knocker
I don't know who makes the gauge cluster. I saw in a mag and cut it out. I'm thinking I have seen them on e-bay. they make the matching ashtray cover and glovebox.
02-19-2003, 11:17 PM | #7 |
Autometer Super & Pro Comp Gauges
Here's a image of the Dash I purchased from Purs.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
02-19-2003, 11:18 PM | #8 |
Who make the second one?
BADASS
02-19-2003, 11:37 PM | #9 |
The second one is going in my chev.
The gauges are Super Comp & Pro Comp.......
02-19-2003, 11:39 PM | #10 |
Who makes the bezel not the gauges
BADASS
02-19-2003, 11:45 PM | #11 |
ok guys anyone with the autometer guages in the cluster could u please post pics of the back side to show the wiring and how to get the turn signals and all to work. i have been thinkin about doing that conversion because it looks sweet and the guages are better but im curious as to how to keep the original turn signals
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-20-2003, 06:07 PM | #12 |
Got those pics yet?
Any idea on a co. that makes the bezel? BADASS
02-20-2003, 06:30 PM | #13 |
BADASS The Bezel is a stock one. For the most part the gauges should slide right in. You prob will have to trim the bottom holes if you run 2 5/8 gauges. I konw the 5 inch gauges will fit in the stock holes.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
02-20-2003, 06:34 PM | #14 |
So the stock holes are closer to a 2 5/8" than 2 1/16"?
BADASS
02-20-2003, 07:23 PM | #15 |
Here is the pic of my gauges. I have a 69 Chevy, I don't know what bezels go with what years. I don't have any pics of the wiring and I already installed the gauges. Everything is wired into the harness at the printed circuit connector. I used a trailer wiring harness so I could make it easy to connect and disconnect. Since my turn signals are in the gauges from the factory, I used 12v lamps in the colors I wanted. I bought them at radio shack.
My bezel was damage by the previous owner and was painted a terrible shade of blue. I painted it flat black and the flaws don't show to bad its just the flash from the camera. This was a practice run. I still need to find a way to mount a fuel gauge in the center. I cut out the holes for the bottom gauges as this bezel type doesn't have them. It works for the time being Last edited by Locutus; 02-20-2003 at 07:27 PM. |
02-20-2003, 10:05 PM | #16 |
Check out this article.
http://www.angelfire.com/retro/67-72/
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-20-2003, 10:23 PM | #17 |
BADASS
02-21-2003, 02:39 AM | #18 |
Resident Young Old Dude !
Do a search for THOR50, He has the absolutely, cleanest aftermarket gauge cluster there is!!!! He took the Autometer's and installed them BEHIND the Bezel.. Hot roddy, yet very, very clean. It still even gives it a somewhat Factory appearance.
RON |
02-21-2003, 11:09 AM | #19 |
The 2 5/8 gauges sit on top of the bezel, while the 2 1/16 will fit inside it. Here is a pic of mine I did circa 1990. I kept the GM wiring for everything, and just added the gauges. Some mods to the sheetmetal housing and plastic circuit were needed.
