07-21-2010, 11:50 AM | #1 |
Brake lines and trailing arms
I am going to replace all the trailing arm/rear end bushings and the brake lines on a frame I picked up. Where is the best place to get this stuff?
07-21-2010, 12:53 PM | #2 |
Re: Brake lines and trailing arms
I'd like to know the best place for brakelines myself. I know there are several vendors on board that sell these items but I'm not in the know of who or where they are.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
07-21-2010, 01:21 PM | #3 |
I bought my bushings from classicparts.com
The rubber brake lines, I bought locally through carquest. I haven't done the hardlines yet, but there seems to be two recommendations I've seen. Most recommend buying the lines and bending your own. Those who do buy pre-bent lines usually mention inline tube. I've also seen mentioned here that the pre-bent lines from LMC are inline brand.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 07-21-2010 at 01:24 PM. |
07-21-2010, 01:46 PM | #4 |
The brake lines kit that i got with my project are from Fine Lines dont know if there any good but thats what ill be use'n
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
07-21-2010, 02:11 PM | #5 |
Active Member
My whole truck is done with lines from the right stuff
http://www.getdiscbrakes.com/RightStuff/Default.aspx The last tube I picked up several weeks ago for another product was all made in the usa stuff Dave also sells to Jegs, Summit and Chrysler amoungest others. The back brake lines where spot on.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree Last edited by 1968SWBBigBlock; 07-21-2010 at 03:20 PM. |
07-21-2010, 04:22 PM | #6 |
07-21-2010, 04:31 PM | #7 |
i replaced the rear hard lines on my 72 burb w/ coated lines from VIP and all 3 brake hoses went bye bye in favor of stainless braided ones from Inlinetube.com.
07-21-2010, 06:57 PM | #8 |
How hard is it to do your own lines? I've never done em before.
07-21-2010, 06:57 PM | #9 |
The Engine Whisperer
07-21-2010, 07:10 PM | #10 |
Comments before seem that Dbl flaring brake lines require special tools and lots of trial and error. Why, take a chance to save a few bucks on something as important as stopping your truck at 70 MPH.
Inline tube is what I used on the GMC they were so close only slight adjustments required. I would use them again.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
07-21-2010, 07:45 PM | #11 |
good point sammy
07-21-2010, 10:52 PM | #12 |
I did my own, and with a good double flaring tool it isn't too bad,unless your using stainless. I also re-routed my lines, moving the rear line to the drivers side, and my front line to go in front of the crossmember, and back to the prop valve. This keeps all the brake lines away from headers and heat, we know heat kills brakes, so why cook the fluid? My .02
07-22-2010, 02:33 AM | #13 | |
I highly recommend the nickle-copper alloy brake lines. No rust, easy to bend and flare (even for newbies). I just recently replace my brake lines from the ABS all the way back to the wheel cylinders on my Durango. And they were bubble flares at that. Perfect flare every time.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
07-22-2010, 09:04 AM | #14 |
Active Member
[QUOTE=ERASER5;4101074.... I highly recommend the nickle-copper alloy brake lines. No rust, easy to bend and flare (even for newbies)..............[/QUOTE]
Where do you get the nickle-copper alloy brake lines from? |
07-22-2010, 10:20 PM | #15 |
AutoZone carries it now. I bought the 25ft roll and cut to fit, flare, and bend.
Eastwood also has a pair of bending pliers for about $30. The pliers are perfect for the nickel-copper lines.
