Old 07-21-2010, 01:30 PM   #1
chevymotocross
chevymotocross's Avatar
LMC Upper control arm question
Re-installing all of my suspension components on my 87' r10. I ordered a new RH upper control arm from LMC truck. The ball joint has a blue cover over the ball joint grease seal. Is this needed for installation or is this just a shipping cover? Without the cover, the grease seal seems to rub the spindle while turning.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 07-21-2010, 10:40 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: LMC Upper control arm question
Do you have a picture of what you are talking about?
I'm not familiar with the "blue cover".
Keith
Convert to disc brakes.
Old 07-24-2010, 08:45 PM   #3
willys72fleetside
willys72fleetside's Avatar
If it a hard plastic cover, then it is used for protection during shipping. The softer rubber dust boot will get sandwiched between the ball joint and the spindle
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline   Reply With Quote
