07-21-2010, 04:55 PM | #1 |
Help with front clip install
Is there a "best" or "easiest" way to install my front clip? I have a 70 C-10. I have the entire fron clip off in complete individual pieces. It was removed to clean each piece and/or discard b/c of rust. The only orginal pieces are the inner and outer front fender, hood and cowl. Of course removal was easy. Looking for some tips to make reassembly as easy as it can be. I do have new hardware for the install also.
11 Surbaban 70 C 10 still in progress |
07-21-2010, 05:02 PM | #2 |
Re: Help with front clip install
I just did this a month ago. I installed the rad support to the frame and then installed the outer fenders. Adjust the door to outer fender gap and then tighten the outer fender bolts. Then install the inner fenders. Install the center grill support and hood latch. The hood can be installed and adjusted. Hopefully you marked the relationship between the hood, hinges and outer fenders. I had to loosen the outer fender to rad support bolts a bit to install the grill.
