house of chevy's
header gasket?
i believe i have an exhuast leak from the header gasket so iv been lookinh on the web and have found several types i was wondering what you guys would recomend to use or what your using thanx
1987 m1028 cucv d30 ![]() 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" ![]() |
Chris
Re: header gasket?
stock exhaust manifold gaskets if you are talking about the ones where the header bolts to the block, if not then aluminum or copper on the collectors since they are reuseable. They make the same ones for the block side but I found exhaust manifold gasket to work great, as long as they are the aluminum perferated looking ones.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
house of chevy's
Re: header gasket?
ya i actually am going to replace both but i was talking about the ones on the block
Re: header gasket?
I have the dead soft ones they sell at pepboys. After you retighten them for about 3 weeks they are perfict. Have not messed with them in over a year. blew 3 sets out of the regular kind. The dead soft are like 50 bucks but 3 sets of the reg are like 60.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
house of chevy's
Re: header gasket?
we dont have a pep boys around here and advanced auto has been out for weeks so started looking online am going to try another place tommarrow but wanted to know what you guys were runin
Re: header gasket?
autozone has some too. That is the only places i go due to location.
Squarebody Aficionado
Re: header gasket?
ok here is the trick, if you have aftermarket headers you can use the regular mr. gasket sets but use 2 on each side, sinch them down good and your problems should be good.
Chris
Re: header gasket?
advance auto has an online store like autozone that you can pay shipping to your house r have it from the website to the store for pickup and avoid shipping, or at least they did, I know autozone still does. Then there's summit, jegs, and amazon.
I have the percy's dead soft alum. collectors, or seal 4 good they call em, comes with bolts and all I tightened them once and that was it, no leaks and no retorque.
Re: header gasket?
just get percys soft alluminum gaskets like 30 bucks from autozone no more worries
![]() ![]() '82 ![]() (Hot Rod) '90 ![]() (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
Re: header gasket?
The gaskets that come with Thorly headers have never leaked not sure what kind they are though.
Re: header gasket?
i've always just used stock manifold gaskets, neve ad a prop! and you dont have to take the header all the way to put them on, or replace them just in case something does happen.
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
At the body shop.
Re: header gasket?
X2. havnt touched mine in a year
" That didnt make it any newer " " Dont antique the equipment " |
#13 | |
Badass
Re: header gasket?
copper ones suck! i got a set and they leaked like hell
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() Last edited by 3r!c84; 07-24-2010 at 05:02 PM. |
#14 |
Re: header gasket?
In my experience the soft copper & aluminum gaskets work very well provided your headers' gasket area are flat. As I've seen with some of the cheaper headers the tube ends are simply sawed off = rough edge. In this case a pass on a belt sander does wonders.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() Last edited by GRX; 07-24-2010 at 06:59 PM. |
#15 |
Re: header gasket?
just get the dead soft aluminum ones and be done with it you can reuse them as many times as needed
#16 |
![]() Join Date: Jul 2007
Re: header gasket?
RTV sealer works too.
#17 |
house of chevy's
Re: header gasket?
thanx guys for all the sugs i was away all weekend but maybe this week i can go get some
