Old 07-21-2010, 08:48 PM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
4x4 1/2 ton to 3/4 ton axles
My buddy has a truck that is suppsoedly a 3/4 ton, that some one has put 1/2 ton axles under. How can we verify that it is a 3/4 ton frame and springs, and what would we need to do to go back to 3/4 ton axles?
thanks.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-22-2010, 01:05 AM   #2
Captainfab
60-66 Nut
Re: 4x4 1/2 ton to 3/4 ton axles
One thing that comes to mind is in my experience the 3/4 tons typically had 56" rear springs. The front springs might have had 3 leafs instead of 2. The only thing that I can think of needing to be changed besides the differentials, is the rear driveshaft.....bigger u-joints on the 14 bolt.
Old 07-22-2010, 09:09 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
The thickness of the metal on the frame rails is different between 1/2 and 3/4 tons. Can't remember the numbers off the top of my head but there were some threads about it not long ago so a quick search for frame thickness might show them.
If you can't find it I will mic the two I have and give you the numbers when I get home.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-23-2010, 07:36 PM   #4
smashingchuck
And for the front you can just change out the outers?
78 Build Thread
4Runner Build
