07-21-2010, 10:37 PM | #1 |
s10 swappers...fuel tank-fuel pump question
hey guys,
i have a 1991 s10 with an in-tank fuel pump. I have new guages with a new fuel sending unit. I have to pull the stock sending unit out replace it with the new one in order for fuel gauge to work properly. My question is should I eliminate the in tank fuel pump while i have it out. Im running a mechanical pump on my SBC350. I have heard that the mechanical will pull fuel thru the intank pump. any advice or tips would be appreciated. thanks brian
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan |
07-22-2010, 02:07 AM | #2 |
Re: s10 swappers...fuel tank-fuel pump question
Personally, I'd pull the intank pump... no matter how you slice it... you're not going to get a decent flow through it. You will also have to plumb a new supply and return line to the tank if you pull the whole sending unit and replace it with just a tank level indicator.
Keep in mind that if your 350 is tbi or tpi, you're going to need an electric pump and not a mechanical, and you definitely won't get enough flow without removing it. Just my two bits, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
07-22-2010, 10:33 PM | #3 |
I'd just use the in tank pump and regulate it down at the motor, and leave the stock fuel lines in (assuming you're using a carb and not injection). TBI only runs 14psi, so it's not too difficult to get it down to 5 or whatever a carb needs. That way, you're still running bone stock s10 parts = easy to find anywhere in the country. The stock GM sending unit is 0-90 ohm, which is what most aftermarket gauges are set up for.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
07-23-2010, 09:06 AM | #4 |
I'd put a pre '85 S10 model setup in your tank, should fit exactly and that was when the dimes had a carb.
07-23-2010, 05:49 PM | #5 |
hey guys,
thanks for the info. I guess i should have said that im running a carb. i think that i might be getting ahead of myself abit. I think that Im going to wire up the fuel pump and sending unit and see what happens to the fuel gauge. If the gauges registers than I will install a pressure regulator to get the psi down. It would be nice if the stock s10 sending unit worked my aftermarket gauge. keeping my fingers crossed but prepared for the worse!!!!
