Old 07-22-2010, 10:20 AM   #1
Lemield
Lemield's Avatar
What kind of pulley is this?
I have never seen a crank pulley like I have on my truck. Can anyone tell me if this is stock or what??? Any help appreciated.
I am planning to put A/C on the truck (still deciding which kit to use).
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-22-2010, 10:24 AM   #2
vectorit
What?
vectorit's Avatar
Re: What kind of pulley is this?
It's actually a two piece unit.
The one closest to the engine is stamped steel, and it's just a single groove model.
The one closest to the radiator is of cast iron, and from my experience has been added for AC or other stuff.
I have one just like it, but I have the two groove stamped steel pulley.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-22-2010, 10:32 AM   #3
Lemield
Lemield's Avatar
Wow Vectorit....that was FAST! Thanks for the info. I'm guessing, based on your response that if I got a two groove stamped pulley to replace the single, I could then use the middle groove for an A/C compressor and then I could still use the bolt on inner groove for my PS pump.
Larry
Old 07-22-2010, 10:49 AM   #4
63chevyll
gets board easy.......
63chevyll's Avatar
man, im not good with the short water pump stuff
63chevyll is offline   Reply With Quote
Old 07-22-2010, 11:03 AM   #5
kwmech
I've got the same pulley on my 68 GMC with the 396. Aftermarket AC.
Old 07-22-2010, 11:16 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
I have that pulley on my factory AC truck with a 350 and PS. My water pump pulley has 3 grooves though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-22-2010, 11:54 AM   #7
48richard
48richard's Avatar
I had the same set up, and when I put in AC I replaced the single groove pulley with a two groove, and put back the other two groove that I already had, so I had four grooves.
One closest to the block is alternator, then AC, then unused, and then PS
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 07-22-2010, 12:26 PM   #8
Lemield
Lemield's Avatar
Thanks everyone. You have all answered my question......again.....this board is a great resource.
Larry
Old 12-19-2012, 01:29 PM   #9
71_ratrod_c20
I have a 71 c20 and the stamped crank pulley is bent does anyone no where I can buy one from
71_ratrod_c20 is offline   Reply With Quote
Old 12-19-2012, 02:25 PM   #10
Lemield
Lemield's Avatar
Wow...this is an OLD thread....
That said, try board member Teeitup....Randy has a large inventory of parts for these trucks...great guy too.
Larry
Old 12-19-2012, 02:29 PM   #11
71_ratrod_c20
how do I go about contacting him
Old 12-19-2012, 02:33 PM   #12
Lemield
Lemield's Avatar
You can send him a private message...member name Teeitup....or you can search the parts forum for one of his parts threads...
Larry
Old 12-19-2012, 02:35 PM   #13
71_ratrod_c20
ok thx sir
Old 12-19-2012, 06:48 PM   #14
48richard
48richard's Avatar
Are you looking for the single groove stamped pulley? I have one that I took off my engine.
Old 12-19-2012, 09:01 PM   #15
bollybib
bollybib's Avatar
Old threads have a lot of good info in them. I like seeing them resurrected now and again.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
