Old 07-22-2010, 12:14 PM   #1
dabear469
Exclamation solumn shift linkage with Lokar
Can someone tell me which Lokar cable shift linkage should be used on a 1969 c-10 Chevy? I need it for column shift. I have the th350 transmission if that helps. Some pictures would be much appreciated if you have some! Thanks in advance!
I was thinking that the Lokar aca-1804 would work for this, but turns out the guy tring to put it on said the cable was to long.
Any suggestions?
dabear469 is offline   Reply With Quote
Old 07-22-2010, 01:26 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: solumn shift linkage with Lokar
I dont have pictures but I had the bar type on my 350/400 and I presently have one on my 4.8/4l60e. here is what I used.
http://www.summitracing.com/search/?...0linkage&dds=1
if you look up some vendors on the forum, they might be able to save you some $ on the purchase.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-22-2010, 02:39 PM   #3
leddzepp
Moderator
leddzepp's Avatar
You need shift linkage (rod)....not a cable. I used Kugel Komponents linkage on my truck (identical to Lokar). I think they offer two versions. Get the kit with the longer shift rod. It will work on TH350, 400, and 700R4 transmissions ( also a few others I think) I used to have a pic, but cant find it. It is VERY simple to install.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-22-2010, 02:51 PM   #4
6772owner
Gearhead
6772owner's Avatar
I used the Kugel column shift kit as well, worked great, you can see pics on my build thread.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
