Next project: 1970 K10
2002 wheels on a 69 C20. Which lug nuts?
I picked up a set of alloy wheels off of a 2002 pretty cheap and want to put them on my son's 69 C20. Are these the correct lug nuts to use on them so that I can snap the center caps on?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Re: 2002 wheels on a 69 C20. Which lug nuts?
No they should have the threads on the outer edge of the lug. The center cap has fake lug nut looking plastic covers and they screw over the actual lug nut to hold the wheels center on.
Ahhhh, that's right. I forgot about that. So, I wonder if anyone makes that type of nut in 1/2"-20?
Check and see if they use the same as a 88 - 98 reg. fullsize chevy. I have alot of them here, if they're the same I'll hook you up.
I'll do that, thanks!
I'll try to check also.
Now that I think about it.... the 69 might have 9/16" lugs. If that is the case, I could probably swap out the lugs for 14mm lugs and use stock 2002 nuts.
Between Trucks...
Stock '69 C-20 should have 1/2" studs. I believe they went to 9/16" in '71 or '72.
Beat it to fit, Paint it to match... ![]() |
OK, thanks. Hmmm.... back to square one.
Between Trucks...
I think the guys running these wheels have been getting their conversion lugnuts off of E-bay. I'm sure one of them will chime in.
Moderator
![]() Join Date: May 2007
You might want to ask member "into69z" We were at the Brothers truck show and a couple guys asked him which lug nuts he used on his 69 C/20 (he has those same new style wheels I believe) Good luck.
SCORE! Thanks for the eBay tip! I found an auction selling lug nuts for Astro vans that have the dual threads, as they even state that is why they sell them are for people doing this swap.
Thanks again!
#13 |
Between Trucks...
Cool. Here's another link: http://www.ezaccessory.com/GM_1_2_Ex..._p/98-0006.htm
#14 |
Junior Member
Lugnutking on ebay
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#15 |
lugking2005 is the one I found. Probably the same cat.
#16 |
![]() Join Date: Nov 2002
http://lugnutking.com/
He's even cheaper on his website than on ebay. I ordered a set from him for my son's '70 and they arrived in two days. |
#17 |
![]() Join Date: Nov 2007
x2 lugnutking on ebay
72 C20 Longbed 05 1500 Z71 |
#18 |
Excellent, thank you!
