Old 07-22-2010, 04:06 PM   #1
cstm68
cstm68's Avatar
tralier brake controller?
is it easy to wire a trailer brake contorller? i have a 2001 z71 is it somthing that i can do myself or a local shop wants 250 for the controller installed, is it worth it?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 07-22-2010, 07:28 PM   #2
52chevy
52chevy's Avatar
Re: tralier brake controller?
You may have a brake controller harness in the glove box if the truck was equipped with the tow package. My 00 z71 had it and the wires are labeled as to where they go on the controller. From there on its plug and play on the inside firewall fuse panel
52chevy is offline   Reply With Quote
Old 07-23-2010, 09:03 AM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
O'Reillys sells a brake controller and wiring harness that is plug and play, no wires to be cut or spliced. Took me all of 5 minutes for a total install. There is a place to plug it in on the fuse block, comes with just enough wire to get it installed down low on the right side of the dash somewhere. Was like $50 for the controller and $20 for the wiring harness.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-23-2010, 11:04 AM   #4
JohnC
JohnC's Avatar
Yeah these trucks are super simple to add a brake controller in. Like Randy said it's a simple plug and play setup.
JohnC is offline   Reply With Quote
Old 07-23-2010, 12:15 PM   #5
fixit-p
fixit-p's Avatar
You can do it yourself and use some of the money you save for a better controller, I've never had a problem with my Tekonsha controller. These may help you. Complete reference can be found here>>> http://www.gmupfitter.com/body_builder_manuals.html
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-16-2010, 04:11 PM   #6
blime81
Laid Lo
blime81's Avatar
I like my Tekonsha Prodigy. Got the harness I needed with it. Plug and play (heck the bracket for it even lines up with the 2 holes on the metal bracket below the steering wheel).
You won't regret spending a couple extra $ to get the Tekonsha either. It's a great controller, mine's been through 2 trucks and I still love it.
https://www.southwestwheel.com/store...rodigy-p2.aspx
Wish I could get paid $250 for an install like that though!
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
