Active Member
![]() Join Date: Oct 2002
Gas tank carpet & paper board
Does anyone have the original carpet & heavy paper board that cover the fuel tank on 67-72 bucket seat trucks, I think they were the same through all 6 years, mine is a 1968
I want to use it as a template to make an exact reproduction. If you have this please let me know your price$ |
Active Member
Re: Gas tank carpet & paper board
ttt
![]() Join Date: Nov 2004
I'm sure you're aware but just in case. They are reproduced although I couldn't say if they are exact repops.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=131
1972 K-10 SWB Cheyenne |
Moderator
![]() Join Date: Jun 2008
I am planning on using a reproduction carpet. Do you know if the cardboard is needed to install the carpet? Or, do you use the carpet instead of the cardboard?
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#5 | |
Active Member
I think that the carpet is glued to the heavy paper board, If you dont use the board you have to glue the carpet to the tank. I like to stay as factory original as I can. Its part of the fun to me, after more than 40 years of different owners removing original parts then adding new stuff, and changing other things around I like to put it all back in order. |
Active Member
Someone out there has to have this, help a brother out!
The reproduction is NOT the same as original, and the the original did attach to aback type board to help hold shape. I made the mistake of buying reproduction for my 71 after I ripped out the original and destroyed the template to make a correct one. I actually removed the plastic tabs from the repop and then reused the screws and grommets to retain the new carpet as original. You might contact Paul Duncan and see if he or Jason has an original unit they could photo and get diminsions off of for you. Paul is a great guy and is willing to help if he has something that will improve these trucks.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
