esc issues.
well ive been having alot of troubles and headaches in that past couple weeeks. trucks been running then cutting off. then starting 2 days later. then not starting. not to mention leaving me on the road twice for tows.
been here and there with it. had new ignition mod put in. then new distributor and problems still showed up. i was told to bypass the esc. did it this morning and the truck is in the same spot as it was the last 2 days. cranking with no spark. it sounds like it wants to go but just wont get there. cableguy has been helping me along the way. much appreciated. just looking to see if theres any other opinions or options. why will my truck not start??? what do i need to get it started and running? pretty sure the pink wire is in the right place and has power. 3 mechanics have had truck and i still have problems. many days without running truck and many dollars to mechanics and i have truck in driveway. my column is loose. anyone know if this is part of the problem? or anything else that i should look at?? at this point i wouldnt mind running a hot wire to battery and pulling wire out everytime i want to park. then tuch wire to batt and go. i know it sounds dumb but i just wanna be able to get it and go. not walk past it everyday on my way to work. |
![]() Join Date: Aug 2001
Re: esc issues.
I have an 82 4x4 long fleet. I bought it about 13 years ago with a crippled up original 305 with esc in it. I replaced the motor & cut out all the esc wireing, & replaced the distributer with a regular old vaccume advance hei. It's been awhile now, & my rememberer is not so pretty good, but i do believe the pink wire is the hot. (verify with a voltmeter) it's just a matter of stabbing a hei dist. & hooking up the hot wire. That'll either fix it or rule out the dist. As a source of no voltage. Good luck. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Truck and auto performance nut
Re: esc issues.
if you hit the throttle body (or carb) with some Ether spray or a little gas...does it fire and try to start? If so...possible a fuel problem? Clogged filter, bad regulator, etc.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: esc issues.
havent tried that. im pretty sure its getting fuel tho.
while i sit there and crank it, i smell fuel. so i think the fuels at carb. just no spark to fire. ive been having problems for a couple weeks with this. 3 mechanics, played, touched, and charged....and i still have problem and have payed 2 tow trucks along the way. i thought the bypass would be the answer and that id be driving today, but after bypass, im in the same spot.... in driveway, not driving. my steering coloum has play in it. and one of the mechanics said it could have something to do with problem?? today while trying to get truck to start, and frustrated, i should the wheel/column a bit while turning key..... and at some point it sounded like it would fire.. but didnt.???? |
Re: esc issues.
now theres a possibilty....a bad column harness?
Re: esc issues.
if so, how hard is fix?
need a new column or harness? |
Re: esc issues.
The first thing to do is pull the steering wheel and tear the column down. Until you get to the 4 bolts that hold the tilt together. Pull the bolts out the rest of the way add a drop of locktite and tighten them back up. After that you need to check the connections on the column. The truck cranking and continuing to have power to the distributor kinda eliminates column wiring.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Re: esc issues.
Well then lmk when you wanna come to jersey and tear truck apart. If I do it it will NEVER get back together
