07-22-2010, 08:28 PM | #1 | |
Future TOTM Winner
TBI fuel pump?
I quoted this from the main "they gave it to us thread" but I separated it to a new thread (obviously).
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
07-22-2010, 08:31 PM | #2 |
Re: TBI fuel pump?
TBI system spec is 9-13 PSI. You can use a 94 through 96 B-body pump on a TBI sending unit. Be sure to use high pressure hose between the pump and sendor.
07-22-2010, 08:33 PM | #3 |
Re: TBI fuel pump?
You can change to a higher pressure pump. The Pump, return line, wiring connections (and maybe a baffled tank) are all there already. Cheaper to change pumps (or maybe the whole pump assy) in a tank that was already designed for EFI.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-22-2010, 09:20 PM | #4 |
Future TOTM Winner
Re: TBI fuel pump?
Cool. So what I was planning to do was to go to the salvage yard and get a TBI sender/pump setup, put a new pump in it, and stick it into my existing 73-86 tank. Sounds like that is a viable way to do it. Thanks guys.
One more thing, I have heard that some tanks are baffled, some are not. Were carbed tanks open and TBI baffled??? Or did I hear that incorrectly?
07-22-2010, 09:56 PM | #5 |
Re: TBI fuel pump?
The TBI tanks are baffled. The carb tanks are not. If you stay above 1/4 tank it wont be an issue. Im running a 91 40 gallon suburban tank in my 85, the 91 was baffled the original 40 gallon tank was not.
07-22-2010, 10:55 PM | #6 |
Future TOTM Winner
Re: TBI fuel pump?
Hmm, that's what I was worried about. I guess I will mock up the build with this one and maybe keep my eye out for a baffled one. For some reason I really like the way this tank fits between the frame rails AND I have 30+
gallons!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 07-22-2010 at 11:15 PM. |
07-23-2010, 09:45 AM | #7 | |
Next project: 1970 K10
Re: TBI fuel pump?
Before I put the 5.3 in my 85, the PO had converted it to TBI with parts from an 87, but had left the 85 tanks in place. The 87 tanks have a shallow bowl that the pumps sit in to keep fuel sloshing away from the pickup during cornering and hard stops. It's not baffles in terms of what you might think of regarding baffles, but rather a bowl. I did have a couple instances of the engine stalling out when I was around 1/8 to 1/4 tank, although I try not to let mine get that low. You must have the 31 gallon tank? Just FYI, a new one would run you about $130.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-23-2010 at 09:51 AM. |
07-23-2010, 10:30 AM | #8 |
Future TOTM Winner
Re: TBI fuel pump?
Thanks Glock. I guess I just need to make a decision and go with it. I have also considered getting the Walbro universal intank pump and modifying my existing carb style sender. To be honest now that I know there are a couple viable solutions I might jut put this concern on the back burner and concentrate on the stuff I haven't decided on...like which way I want to go with my wiring harness!
08-14-2010, 04:27 PM | #9 |
Re: TBI fuel pump?
Good thread guys-very helpful. I need an EFI tank for my 65 SWB swap. Sounds like the best candidate is the 87-91 Blazer/Sub tank. What would be very helpful is the dimenesions of the tank/tanks. Sounds like some have more capacity so if anyone has access to these tanks,I would be very grateful for some measurements.
09-10-2010, 07:25 PM | #10 | |
Re: TBI fuel pump?
(copy/pasted from Classic Parts www page) Think I'll do the 40 on my K5.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
09-10-2010, 07:43 PM | #11 |
Re: TBI fuel pump?
Is there any truth to this statement I heard "to much fuel line pressure can overheat the fuel by returning it to the tank to fast? I was looking at a tbi camaro and a guy told me to try and use the stock fuel pump.
02-07-2015, 10:41 AM | #12 |
Re: TBI fuel pump?
any one know what yr i can find the 25gal tank. looking on rockauto an can only find 31 gal. my truck is dropped an prefer the 25gal one. thanx in advance
02-07-2015, 01:00 PM | #13 | |
meowMEOWmeowMEOW
Re: TBI fuel pump?
The person who put up the dimensions said they were from Classic Parts, so it might be worth looking there. edit: I was nice and did the finger-work for ya; all 3 25 gal options http://www.classicparts.com/1973-81-.../#.VNZEoy6GOok http://www.classicparts.com/1982-86-.../#.VNZErC6GOok http://www.classicparts.com/1987-91-.../#.VNZEsy6GOok
02-08-2015, 03:17 AM | #14 |
Re: TBI fuel pump?
Thanx brew city. The 87-91 is one i need for my ls swap. Thanx a bunch ordering it monday
02-08-2015, 03:34 PM | #15 |
Re: TBI fuel pump?
Anyone know the part number to the sender/intank pump assembly for this tank? I have seen a bunch but none say the measurements of the mounting flange/ring. And not sure if the size is universal other than depth based on the capacity of the tanks.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
02-09-2015, 12:59 PM | #16 |
Re: TBI fuel pump?
im guessing it would be this one. http://www.classicparts.com/1987-Gas...tinfo/23-569/#
took me a few times to find the one for 25gal. then all that would be needed is to switch out the pump to the EP381 pump for the 60psi. Brew City does this sound correct |
02-09-2015, 08:30 PM | #17 |
Old member
Re: TBI fuel pump?
I have a 93 surbarban tank in mine with a aftermarket LS pump at 62lbs I think is what they said it rated at. My tank is 40-42 gallons has baffels with the little circular part around the bottom of the tank to keep the gas close to the pump.
I had a 30lbs pump in it before for the 305 TPI motor. I just had them swap it out. I did drive the truck for a week with the old pump. It gave out though thank goodness in the drive way.
02-10-2015, 02:42 PM | #18 |
meowMEOWmeowMEOW
Re: TBI fuel pump?
The ep381 or any of the Walboro-style in tank pumps. The 255 is sold by like 20 companies under different names. It does just under 100psi, which is regulated to 58-62.
02-10-2015, 09:39 PM | #19 | |
Re: TBI fuel pump?
I also want to try the smaller tank so it doesn't hang down too far (I'm one of those guys who's all picky about seeing the tank).
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
02-11-2015, 01:42 PM | #20 |
Re: TBI fuel pump?
finally got around to ordering it last night. may be a few wks before pix
