07-22-2010, 09:19 PM | #1 |
It's Alive
Finally got most of the parts together and started monday putting the Offy intake and Holley 350 2bbl on the old 230 in my 65 C10. Set the carb up with the float bowl facing the new Offy vc. More room for the linkage on the outboard side. And my manual choke hooked right up. Made a new gasket for the heat plate and hooked it up too. Ran one hose behind the motor. No room around the thermo housing. Bent up a fuel line around the back to the fuel pump. Started up this mornin'.
Runs nice. No leaks so far. Waiting for a bellcrank to hook up the loud pedal. Then test drive time!!! Last edited by geezer#99; 07-22-2010 at 09:21 PM. |
07-22-2010, 09:21 PM | #2 |
Re: It's Alive
that's cool. you just don't see hot rod inlines anymore.
local guy used to show his truck and had a 292 with dual carbs |
