07-22-2010, 11:53 PM | #1 |
Noob needs help w/ steering column / ignition!!
Hey guys, I have a 1979 GMC K2500 long bed w/ a 5.7 that I'm tinkering with. This truck has a ton of little things wrong with it but I'm fixing things one at a time. I put in a new battery and starter and the truck would turn on and crank. Next item was the old factory ignition key cylinder. You had to crank on that thing with all of your might to get the truck to turn over. It was shot. I ordered a new one and put it in. I put everything back together the way it came apart except for one little item. That damn retaining clip that holds the steering wheel lock plate down flush. It's spring loaded and a total PITA. That thing is impossible to put back on without some sort of crazy vice contraption. Anyhow, now my truck doesn't get ACC power nor turn over at all. I even took it back apart and put the old ignition cylinder back in and still no juice. My worthless Chilton's manuals don't have any fuse information. Any ideas??? Thanks!
-Eric Last edited by ericcasas; 07-23-2010 at 12:02 AM. |
07-23-2010, 12:57 AM | #2 |
Re: Noob needs help w/ steering column / ignition!!
Yo! Vise contraption:
http://67-72chevytrucks.com/vboard/s...highlight=horn $13 at NAPA. Check your fuses (the box is labeled) and connections. Finally, some of the ignition wires have internal fused links that may have fryed. Check for 12V+. Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! Last edited by asphaltburner; 07-23-2010 at 12:58 AM. |
07-23-2010, 01:06 AM | #3 | |
-E |
07-23-2010, 01:38 AM | #4 |
Yo! Thanks!
The rear-facing edges of the fusebox on my '78 are embossed with the names of the fused items. I could get you a pic of mine if you cannot see anything with a bright light. My FRANKENTRUCK is a '78 K20. Again, thank you. I'm glad the info/pics helped! Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
07-23-2010, 01:21 PM | #5 |
All About the BOWTIE
Did you try replacing, or fiddling with the ignition switch itself, mounted on the column... In the past, I've had to replace the rack and sector set-up, and new cylinders with Chevy truck Columns... and seen that rods go down, and activate the switch. I replaced my non-tilt column, for a tilt one, in my 84. I had noticed that with the old column, that sometimes the starter would click, or drag when i went to start it.. like it was a bad starter, or something was starving it for power.. i.e.. bad connections or something.. anyway.. after the donor column... thing fires up all the time every time.. like a champ!, which was a total fluke, because I didnt realize to even check that for the problem, and discovered that these switches have lots to do with it (distributes juice when its activated, to gauges, ACC, and so forth)... hope this helps....
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-23-2010 at 01:26 PM. |
07-23-2010, 01:38 PM | #6 | |
-E |
07-23-2010, 01:42 PM | #7 |
I have a Chilton's that goes back to 80,... yours is a 79, can't see there being much difference.. heres a diagram for a 80 C/K....
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
07-23-2010, 01:51 PM | #8 |
Here's a pic of what it looks like.... It's number 25... im pretty sure you can get em from any parts store..... It's located right at the base of the column.. your gonna have to look up under there... remove that metal plate, and plastic moulding thats under the dash bezel,.. under the steering wheel...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=161
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 07-23-2010 at 01:51 PM. |
07-23-2010, 01:53 PM | #9 |
actually number 24.... lol my catalog, and the online one are different
07-23-2010, 07:11 PM | #10 | |
-E |
07-23-2010, 07:43 PM | #11 |
Good luck Bro,.. Hope it all works out for ya!
07-25-2010, 01:50 AM | #12 |
Well guys....I rented the tool to put that retaining clip back on. Boy what a difference. I can now officially take off my steering wheel as fast or faster than a NASCAR pit-crew.
I put in the new ignition switch and made sure that the rod was adjusted to specs and that it coincided with the turning of the key in the key cylinder. Still no juice. I checked all of the fuses in the fuse box and nothing is blown. I guess I'm down to fusible links. The Chilton's manual I have covers just about any GM truck from 1940 - 2020 and talks about each truck for a paragraph. I need to buy me a year specific complete Chilton's book (the ones the size of a phone book). The book I have is worthless. Is there a specific fusible link that you guys know of that I can try to snuff out? I guess it's possible that it could be the problem because as I kept trying to turn the truck over...over and over again, it kind of just suddenly went out. I'm guessing it might have heated up and just gave out? Recap: New Battery New Starter New Starter Cable New Key Cylinder New Ignition Switch (tied by a rod to the key cylinder) All fuses good. Pretty soon, my truck will be under full limited lifetime warranty from my local O'Reilly's due to replacing every F-ING part on this thing!!! Any further advice is sincerely appreciated but it's now time to crack open this 18 pack and get my swerve on. -E |
07-25-2010, 10:12 AM | #13 | |
Still plays with trucks
All the stuff you have been doing may have killed it. Also you could have a draw on it somewhere in the system that is killing the battery. May be why you needed a new one in the first place.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-26-2010, 03:51 PM | #14 | |
-E |
07-26-2010, 04:03 PM | #15 | |
See if you can jumper the solenoid trigger wire to the primary power terminal to make it turn over. If you have exhaust manifolds this is pretty easy but not so with headers.
07-26-2010, 05:59 PM | #16 |
It followed me home?
My old '85 did the same thing and it was the damn ground wire on the back side of the pass head, I also ran a ground to the alternator bracket and it never gave me any other issues
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-26-2010, 06:11 PM | #17 |
^^ x2 i did the same thing and never had a problem again
07-27-2010, 11:43 AM | #18 |
^^ Interesting on the ground wires. The way the truck was set up when I bought it, the starter didn't have the ground wire installed but started just fine. As it sits right now, there still is no ground wire attached to the starter. I guess I'll run one up to the alternator bracket like you guys suggested just in case. I'll also do the jumper wire test tonight after work.
-E |
07-29-2010, 11:13 PM | #19 |
Performed the jumper test and the starter tries to crank. Somehow or another, there's an open wire between my ignition switch and the solinoid. Is there a fusible link between the two? Any idea where it's located? Once again, appreciate all of the feedback.
-E |
07-29-2010, 11:35 PM | #20 |
Well....finally found an actual year specific manual. 1100 pages worth of actual factory info:
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT Now I can figure this stuff out for myself. In the meantime, if you guys can direct me towards that fusible link location, I'd be much appreciated!!! -E |
07-30-2010, 11:30 AM | #21 | |
07-30-2010, 11:44 AM | #22 |
68TT, I should still get ACC to come on but just no crank if that were the case. My truck is as dead as a door nail. It's got to be wire related from the ignition switch down to the solinoid.
07-30-2010, 11:51 AM | #23 | |
Also try to cycle the ignition switch with it off the column and see if it works. The fusible link is usually up close to the positive battery terminal and has a small plastic connector joining the typical 10 gauge red wire from the battery terminal to a section of more flexible smaller wire.
08-06-2010, 03:51 PM | #24 | |
-E |
08-06-2010, 03:59 PM | #25 | |
