07-23-2010, 09:58 AM | #1 |
Who's got steelies?
Breakerless ignition...Anyone tried it???
I found this at http://breakerless.com/ and it looked like it might be nice, but I wanted to see if anyone here on the boards has tried it.
Any thoughts?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
07-23-2010, 10:17 AM | #2 |
Re: Breakerless ignition...Anyone tried it???
I bought a 71 burb with one in it, i don't like it , motor has to turn a lot before it cranks.jmtc.
07-23-2010, 01:35 PM | #3 |
No on the Breakerless.
WE did use a Pertronix on a 6-cyl with great results. I would suggest using their coil as well. Good Luck MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
07-23-2010, 04:21 PM | #4 |
I have a Pertronix Ignitor in my 250 and it works great. I think I paid about $50 for it 3 or 4 years ago. Definitely worth not having to mess around with points. Would not be so bad if the 6 cyl distributor caps had the window like V8's to adjust the points.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
07-23-2010, 04:22 PM | #5 |
One thing to note on that type of ignition is, you need to remove the stock resistor wire.
