Old 02-19-2003, 11:16 PM   #1
70jimmy4x4
steering box question
I removed my steering box for replacement, BUT, is there a way to test it BEFORE I fork-out 185.00 for a new one ?
Steve
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
Old 02-20-2003, 11:44 AM   #2
*MJF*
No longer truckless
I don't know the answer to your qeustion, but the $185, is that for a manual or power steering box?
*MJF* is offline   Reply With Quote
Old 02-20-2003, 03:59 PM   #3
TX_Mudder
$185 sounds about right - that's what they quoted me at Autozone.
Dumb question - if you don't know if it needs replacement, why did you remove it?
If it's leaking, you can buy seal kits.
If your steering is sloppy, there are a multitude of other parts that are more likely - rag joint, balljoints, tie rod ends, drag link ends.
Sorry, I don't know of any way to test a steering box.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 02-20-2003, 09:50 PM   #4
70jimmy4x4
Well, now THERE is a question.... I guess I approached this thing as a "sit it in the garage and throw money at it" project !!!!
Been through the rag joints, tie rod ends, and wheel bearings.
After readin these responses, andother postings on this board, I am bolting the thing back on and going after the u-joints.
A couple of people have mentioned that because of WHAT it is doing, (drifting one way, then the other) it is likely u-joints....
Wish me luck !!
p.s. It is 4x4 w/ 4" lift. THERE ! That's the problem !! LOL
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
Old 02-20-2003, 10:12 PM   #5
6869704X4
I was going to post this pic in my xover steering thread. Its how I want to tighten up my steering. Its racecar parts from coleman. About $125 for the u-joints and rod. Its a van tilt wheel.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 02-21-2003, 02:55 PM   #6
lugnut
lugnut's Avatar
steering box
You might check a hydraulics shop. Some shops that work on HD trucks have the ability to bench test steering sectors.
lugnut is offline   Reply With Quote
