Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-23-2010, 01:06 PM   #1
F-85
Suspension help on 65 GMC
I got a 65 GMC short step with leaf spring rear. Its gonna be a street/strip truck. BB and th400. Running 295/50/15 tires. 3.54 with powertrax. What do i need to do to get this thing to hook?
F-85 is offline   Reply With Quote
Old 07-23-2010, 08:34 PM   #2
shortbed70
shortbed70's Avatar
Re: Suspension help on 65 GMC
Sticky tires and a prepped track! Honestly these trucks on street tires spin like crazy on the street. I cant get my 65 coil truck to hook on street tires and I'm sure leaf springs are worse. To start I would say good shocks that are adjustable and more rear percentage.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-23-2010, 08:48 PM   #3
cableguy0
You will likely need a set of cal tracs. With a big block i wouldnt want it hooking too hard with a powertrax. you will end up sweeping it up off the track.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-23-2010, 09:06 PM   #4
shortbed70
shortbed70's Avatar
BTW I have bfg 295-50-15 on my truck.
Troy
Big Red Dog build
Old 07-23-2010, 10:30 PM   #5
F-85
I looked up Cal tracs, but they dont make them for the 60-66. Will the 67-72s fit?
Old 07-23-2010, 10:43 PM   #6
cableguy0
Theres really no reason a coil truck doesnt hook up. There are guys on here going faster than 10.0 with the stock setup and nothing more than a set of coil over shocks and drag shocks in front. I cant give an honest answer on whether the 67-72 stuff will fit your 65 but as far as i know the rear suspension is pretty much identical.
Old 07-23-2010, 10:51 PM   #7
F-85
I got leaf springs in the rear.
Old 07-23-2010, 11:07 PM   #8
cableguy0
I know I was answering both posts at the same time. I should have seperated it. I know the coil sprung setups are the same on the 65 and the 67-72 im just not sure if the leaf spring setups are the same. Im sure someone else here will know for sure. Leaf spring guys swear by the cal tracs.
Old 07-24-2010, 12:07 AM   #9
F-85
Cool ill look into it more. I was just gonna add traction bars.
Now what about the powertrax? Are they junk or something?
Old 07-24-2010, 12:15 AM   #10
cableguy0
They arent known for holding up to a bunch of horsepower with traction. The better choice is an eaton clutch type posi but that requires the rear to rebuilt
Old 07-25-2010, 09:02 AM   #11
djracer
djracer's Avatar
I would swap to trailing arms and coilovers if I were you. Look for a donor truck or buy after market arms and a good coilover kit. The sticky tire will help a ton.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-25-2010, 09:26 AM   #12
F-85
This is just going to be a driver truck. The track a few times a year. Looking at mid 12s. You dont think i can get it to hook with leafs?
Old 07-25-2010, 09:43 AM   #13
djracer
djracer's Avatar
You can with caltracs but I would either do trailing arms or caltracs. I would call them I'm sure they can get you a set that will work on your truck.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
