Squarebody Aficionado
lowered trucks with inner fenders
I know once you cross over to the low zone you have to worry about your truck bottoming out on your inner fenders what i wanted to know what solutions have you guys taken, other then just removing them all together. I was wondering if maybe you can just move them up an inch or so.
6.0 powered square
Re: lowered trucks with inner fenders
I added some stubby bump stops on mine I have 27" tall tire on mine, before they would scrub on every little bump
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Badass
i was thinking the same.mine rub but i dont want to lift the front .i want to go lower
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
I had the same problem with mine rubbing every time I hit a bump, till one day I was driving along about 60mph and hit a little dip in the road on the drivers side, the tire rubbed the fender so hard that it threw me into the other lane....wasn't long after that I took them out.
Happy to be here
![]() Join Date: Mar 2000
Here's what I had on my 77 before the Ride Tech re-do. The second pic shows what I am running now. This allows me to air out and still roll.
dang its hot
I attacked this problem from a different view...the supension is lowered so I raised the inner fenders...
how did you raise the inner fenders this is what i was thinking of doing, i had my stock bumpstops on there and it never rubbed but being a moron, i looked at them one day the truck was on the lift and said ****, maybe i dont need these, boy was i wrong. I was just thinking of putting some new ones back on but they were only like 1.5" from hitting when the truck was on the ground.
Im kind of leaning towards moving the stock fenders up, mind showing us some pics and how you did it? |
If you can find one big enough for your rims, how about using a single wheel trailer fender mounted in there?
GM Addicted
so is there a bad thing that happens with removing the bump stops other then hitting your inner fenders??
..Mac’s Garage..![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Why not remove the inner fenders, and go with a cheap set of custom fenders? All you need to do is get some sheet metal, or aluminum and just bend it using a metal break.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
Happy to be here
Guys, just removing the fender liners does not cure your problems. If your going that low, you will need to cut the inside of the fender as well. You can section that area and move everything up, but it requires a LOT of cutting, welding, and body working skills.
Happy to be here
Yes, your going to beat the fillings out of your teeth when you bottom out. And you will bottom out.
#13 |
I built this bumpstop extension. When aired out on a 205/70/15 tire I had a quarter inch of space between the tire and innerfender.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
#14 |
GM Addicted
It would only bottom out once i air out correct and if i dont cups my down to much the a arm should touch the upper plate mount correct
#15 |
Happy to be here
It has the potential to bottom out regardless of how much air you are running. It just depends on the circumstances. Speed + load x dip in road= suspension reaching it's lower limits.
#16 |
Garage wrench
That's an awesome idea, I think I may do that but the opposite. I think the spacer and stop on the control arm would work best for me. I see it probably would not work for you as well with the tubular a-arms but I have stockers and it should work well. Much like N2TRUX's old set-up but modified a little bit. Thanks for the ideas guys.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 07-26-2010 at 08:05 PM. |
#17 |
well if i was to put the stock bumpstops back on my truck i wouldnt be rubbing anymore but i will almost be ridding on the bump stops every bump i hit.
#18 |
I took my bump stops all the way out for now. I will put some short ones in soon though, with the stock bump stops I was riding on them and the ride was terrible. It improved when I took them all the way out but the suspension will bottom out quicker..
| Bookmarks |
