Windhield washer bottle questions
I have a 69 4x4 and it's missing it's washer bottle and I can't find the wiring under the hood or where the washer bottle would go. I'm betting it got buried by the PO.
I'll buy a bottle and pump and hose from LMC or something, but does anyone know where the bottle goes and what the wiring is for the pump so it'll work from the washer switch inside the cab? -Steve
1969 Chevrolet 4x4 C10 Pickup |
Between Trucks...
Re: Windhield washer bottle questions
12 volts key on to the red wire for the pump, I ran from the wiper motor for this. Ground wire from the pump to the middle connector at the wiper switch, (blue factory wire goes to this connector). I went to pick a part and got a washer bottle out of a sedan that mounted up to my drivers side inner fender.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 07-23-2010 at 05:36 PM. |
the stock pump is up under the dash in the drivers comp attached to the wiper motor. the bottle mounts on the driver side inner fender the pump sucks the fluid from there and squirts it on the windshield
PUMP IS NOT ATTACHED TO THE BOTTLE in a factory setup
Between Trucks...
This is true. My instructions are for an aftermarket washer pump.
Beat it to fit, Paint it to match... ![]() |
The Older Generation
Here is another thread on the subject... http://www.67-72chevytrucks.com/vboa...d.php?t=217477 LockDoc
The stock pump is a real PITA to get to. Instead of replacing it I used a universal pump and mounted it to firewall. I ran the positive and negative wires from the stock connector I removed from the old pump.
#7 | |
Still plays with trucks
I already put one on my 78 to fix a defective stock on-motor washer pump and broken aftermarket external electric pump. http://67-72chevytrucks.com/vboard/s...4&postcount=11
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Just the ticket, boys, thanks a lot. More than enough information to work this out now. That 88-98 bottle looks just the ticket ...
-Steve
