Old 07-24-2010, 12:18 AM   #1
71GMCinTN
Any alum. polishers in the house?
Time to get these valve covers redone... anyone have any advice for a first time polisher? Learning what I can, and seems like alot of messy work, but seems it would be rewarding to learn, and save $ in the future. (or if someone here is set up to do it, and enjoys it... and wants to do these...lol)
71GMCinTN is offline   Reply With Quote
Old 07-24-2010, 01:39 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: Any alum. polishers in the house?
one way i polish aluminum is by sanding with a fine grit sand paper, like 2000 grit or more. i've had more luck that way. but you can try to get some never-dull and use that. if you are looking to take the pits and imperfections out then first i would do the fine grit sanding then use the never-dull. this process takes time and patience, but will pay off in the end. and you don't have to switch out the sand paper very often. i find that using a piece that has collected a bit of metal dust actually polishes better than a wet sanding job. and after a round or two of the 2000 grit you can go higher and higher until you get it where you want it.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 07-24-2010, 05:39 AM   #3
cdowns
cdowns's Avatar
i'd start those off with brillo soap padds to clean them up then to a quality polish//they should clean up really easily because they aint very bad to start with
Old 07-24-2010, 07:36 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
not sure if they have been washed yet butt hey don't look to bad..heres what I would do
wash them really well with mag wheel cleaner ( acid)
then depending on how they look ( should be flat not shiney) I would either
put a buff wheel in the drill press and hit it with some rouge ( you can buy a kit at just about anywhere) grap a pair of gloves and get to work..the problem with any of these ideas it sthe deep corners??
if there not to bad I would try one of two products either Flitz or S100
Flitz it available in alot of places I have had really good luck with this stuff and they have some great tips on there website. This stuff works just like any other polish but keep in mind a little of this goes a long way
now the S 100 ( got it at harley dealer) is completly dif....it comes in a round polish bucket with a sponge on top...you use this stuff with water and it cleans and polishs VERY WELL. I found this to be the better of the 2 for stuff with odd surfaces like your covers or wheels
after thought is
if you want to help get them clean use a soft tooth brush and Bonami ( its a scowering cleaner it looks like comet without the harsh grit so be sure to use it by NAME) its in the grocery store
hope this helps
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 07-24-2010, 09:08 AM   #5
71GMCinTN
Good ideas....... Did go by a carwash and sprayed them off yesterday. Was afraid to use the wheel cleaner on them. Used it on the Edelbrock Performer and Torker II intakes. Made the Torker II real chaulky. Was using some Never Dull on them last night, but didn't seem to be getting anywhere. Used to have some Flitz. Have access to a nice bench grinder, so I may buy some buffing wheels. Had also considered powder coating them Dormant Blue & clear coat. Know nothing about powder coating in general.
Old 07-24-2010, 09:18 AM   #6
71GMCinTN
Happen to know where a box of Brillo soap pads are, so going to try them real quick...
Old 07-24-2010, 11:51 AM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Most if not all grocery stores sell them.. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-24-2010, 01:22 PM   #8
HOGDADDY
HOGDADDY's Avatar
Here are some buffs and compounds to use.
http://www.eastwood.com/buffing/meta...13-pc-set.html
HOGDADDY is offline   Reply With Quote
Old 07-24-2010, 02:34 PM   #9
big_al_71
big_al_71's Avatar
post some pictures of the finished product!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 07-24-2010, 03:14 PM   #10
Notrodder
That task seems like it would be a real pain and may yeild only mediocre results.
Here's another idea, sandblast them. Then with some 220grit on a small block, sand just the highs and leave the lows blasted. You could go with progressively finer paper 'til you get the polish that you like.
This would certainly be easier and might look real good.
Notrodder is offline   Reply With Quote
Old 07-24-2010, 05:02 PM   #11
GRX
GRX's Avatar
I am a Machinist/Metalsmith and have a fair amount of experience polishing metals - from Chrome to Platinum. Cardinal rule ... clean thoroughly between grits. In other words, remove ALL particles, or you won't get anywhere. This goes for both sandpaper & buffing compound.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-24-2010, 05:25 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wash em, then brillo pad and eagle 1 etching mag wheel cleaner then some find paper and maybe some mothers alum polish is what id do (dont gotta be perfect but just purty good) (I have dd's and they'llg et dirty!
btw, SWEET VAVLE COVERS I LOVE THE RETRO OLD STYLE VALVE COVERS!
John
1999 Toyota Tacoma 4x4
Old 07-25-2010, 04:20 PM   #13
68K30
I use progressively finer silicon carbide paper starting with 400 grit, lubed with WD-40 [wet sanding] then finish with Mothers polish, small red and white container with screw on lid on a cloth rag. Try it you will be amazed, I polished some parts on a South Bend lathe I was re-doing and you can see yourself in all of the parts and was very easy to do. I forgot to mention the part were 'as cast' when I started.
68K30 is offline   Reply With Quote
Old 07-25-2010, 09:45 PM   #14
Shane
Shane's Avatar
you can also use kerosene with your sandpaper ... works miracles on cast aluminum
Shane is offline   Reply With Quote
