Old 07-24-2010, 07:08 AM   #1
maxwedge528
eliminate stepside tailgate chains?
i have tried several searches but have not seen a solution to: how do you eliminate the chains for the tailgate and install something like the fleetside hinges? i have seen mention of this but not how to...maybe it is so simple that it does not need to be explained?? perhaps someone could provide a thread or just how to! thanks..
maxwedge528 is offline   Reply With Quote
Old 07-24-2010, 07:33 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: eliminate stepside tailgate chains?
check out this link from Mar-K
Hopefully, this is what your looking for
http://www.mar-k.com/what_s_new_at_mar-k.html
Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 07-24-2010, 12:12 PM   #3
Sammy
My GMC step I used the MAR-K. Works good. Seen some use various late model cables and cabinet or screen door latches. Actually making your own custom cables wouldn't be hard at all. The hardware store sells garage door cable cut to length along with the keepers and stops. Very reasonable. .29 a foot for the 3/8 cable last week for the stuff I used to hang a light in the garage.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-24-2010, 03:40 PM   #4
maxwedge528
thanks guys. i looked over the mar-k site and probably will order the two kits.
Old 07-24-2010, 04:32 PM   #5
LONGHAIR
I have seen it done several times with S-10 cables.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
