Old 07-24-2010, 10:18 AM   #1
jcsbrat
jcsbrat's Avatar
Fuel filter location
I'm wondering where the fuel filter on a 1972 Chevy truck is? It broke down on me and is stranded at a gas station and im wondering if i can change it where it sits. Cause i hate to have to pay to have it towed.
K-
jcsbrat is offline   Reply With Quote
Old 07-24-2010, 10:32 AM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Fuel filter location
what carb do you have? the best i can tell you from this is the q-jets and similar had them in the carb were the fuel line goes in, or if an aftermarket carb it should be in the fuel line
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-24-2010, 10:35 AM   #3
68gmsee
Active Member
68gmsee's Avatar
The factory ones are inside the tank -a sock at the end of the fuel inlet tube and one inside the carb where the fuel intake tube goes in. Remove the large nut and the filter is inside. As for the gas tank one, the only way to check it is to remove the fuel sending unit.
It could have another on installed anywhere along the fuel lines. Even on the bottom of the cab so check carefully.
68gmsee is offline   Reply With Quote
Old 07-24-2010, 10:56 AM   #4
cdowns
cdowns's Avatar
if the tank strainer sock is plugged you can remove the inlet hose rom the pump and blow back into the tank with lo pressure(less than 25lbs) to clear the sock for a very temporary fix to get you home
the carb filter if plugged you remove the filter from the carb body , spray the housing real good with carb cleaner prior to installing new filter
Old 07-24-2010, 11:48 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if blowing the fuel lines... make sure to remove the fuel cap first. Otherwise you WILL get sprayed with fuel when you stop pressurizing the tank.
We won't discuss the way I learned this. Just loosen the cap.
Old 07-25-2010, 12:36 AM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I'm willing to bet that sock in your tank is going to be the source of your clog-on both of my trucks that thing had turned to brittle mesh, with half of it hanging out in the bottom of the tank.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
