Old 07-24-2010, 07:57 PM   #1
rennalds
Fuel Filler
Ok so we installed a Poly Blazer Tank on my sons 71. We used a marine filler and 1.5" flexible filler hose, problem was the neck on the poly tank is 1 3/8". We clamped down on it really good but now its leaking. Anybody have any suggestions? We can't seem to find a reducer that small anywhere. I have seen other posts talk about welding a new spout on, but since it's a poly we dont have that option. Thanks in advance for your help
rennalds is offline   Reply With Quote
Old 07-24-2010, 08:01 PM   #2
vectorit
What?
vectorit's Avatar
Re: Fuel Filler
If it's like my burb.
The hose size is an odd ball ID measurement.
I got mine at a industrial hose supply house, it is USCG fuel rated and it fits just right.
The shop I get stuff like this at is a shop that caters to heavy equipment hydraulic hose and fittings, check around your area for such a place and I am sure they will set you up right.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-24-2010, 08:03 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: Fuel Filler
I had the SAME problem. I bought my 1 3/8" filler hose from West Marine. Tightened it down....no more leaky.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-24-2010, 08:03 PM   #4
faribran
Re: Fuel Filler
might try cutting a short section of another hose(the correct diameter) to use as a filler.
faribran is offline   Reply With Quote
Old 07-24-2010, 08:17 PM   #5
rennalds
Re: Fuel Filler
I found some 1 3/8" hose but the filler is 1 1/2"
Old 07-24-2010, 09:38 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fuel Filler
i built up the 1 3/8 with jb weld
John
1999 Toyota Tacoma 4x4
Old 07-24-2010, 10:57 PM   #7
Sammy
Re: Fuel Filler
I went to Auto zone spent 30 min looking thru the adapters for tail pipes to come up with a combination to work on the Hose I got from the boat supply dept. Take a tape measure with u.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
