Old 07-24-2010, 08:34 PM   #1
kcfirstbuild
Should i add lucas to my differential ?
Should is use Lucas oil stabilizer in my differential with a quart of 80-90 or should i use two quarts of " lucas 80-90 gear oil" or just use two quarts of 80-90 and be done with it. I have 12 bolt on my 1968 c-10. I have been using lucas of a long time and just thought since i was changing the fluid out i might use some in the rear . but wanted to hear what everyone thought.
I'm going to stay away from synthetics, im not building a speed demon.
kcfirstbuild is offline   Reply With Quote
Old 07-24-2010, 09:47 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Should i add lucas to my differential ?
I have never used any Lucas in a differential, but would be interested in what others have to say.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-24-2010, 09:58 PM   #3
cdowns
cdowns's Avatar
best bang for the buck is synthetic// i use only mobil one or roryal purple in everything i own
Old 07-24-2010, 10:15 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Why not run synthetic, ive heard its the way to go on rearends..
John
1999 Toyota Tacoma 4x4
Old 07-24-2010, 10:37 PM   #5
msgross
msgross's Avatar
I used lucas synthetic in the rear diff of my daily driver, stopped the posi-chatter (added additive as well) and shouldn't have an issue ever... it's a little cheaper than royal purple
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-24-2010, 10:40 PM   #6
kcfirstbuild
To many stories of syn leaking in older vehicles. maybe they had other problems too
Would like to find some one that put lucas in before i become the Guinea pig.
It says right on the bottle for diff's though
Old 07-24-2010, 10:42 PM   #7
kcfirstbuild
what about just the oil stab from lucas and a quart of 80-90 ?
Old 07-24-2010, 11:39 PM   #8
Rob H.
Rob H.'s Avatar
I haven't tried it in a rear end but works great in an auto tranny! I'm sold on their products.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 07-24-2010, 11:40 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
new oils don't need additives. Most synthetics don't even need posi lube added.
There is no real reason NOT to use a quality synthetic lube with the exception of cost. And if it leaks after filling with synthetic, you already had a problem.
While some of the lucas additives are worth something, some of them are snake oil. I highly doubt there is anything in there gear lube that a quality synthetic lube doesn't already have.
Old 07-25-2010, 01:21 AM   #10
1969stepside
1969stepside's Avatar
80-90 conventional valvoline is all i use
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 07-25-2010, 01:37 AM   #11
yote1234
yote1234's Avatar
lucas. shure..i did.
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 07-25-2010, 08:51 AM   #12
LONGHAIR
ZZZactly^^^
The only thing that I would add is that I would definately run a synthetic with new gears, from day one. The heat generated by the rear gears is significant and synthetics deal with it much better.
You can review the site's rules here.
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-25-2010, 09:08 AM   #13
kcfirstbuild
They are 42 year old gears. I did put new seal, bearings and cover gasket so nothing should leak.
Ill just put some fresh 80/90 in.
Old 07-25-2010, 09:13 AM   #14
mdwilf
mdwilf's Avatar
I know this might sound like a "fishing story", but it's true.
Anyway... I had a 72 1/2 ton 2wd that had been run really, really low on rear diff oil - sounded like a jet at full throttle going down the road. I drained it & filled it will Lucas Oil Stabilizer & within a few miles it was almost totally silent. I ran it several years that way (prob 6 or 8k miles) - towing, scrapping, yanking, etc. It finally died when I got stuck during an ice storm & decided I'd get it out or break something. Ended up being the latter - came apart so hard that gear pieces dimpled the housing & it wouldn't hold fluid anymore.
I'm not 100% convinced that Lucas will do much more for your motor than slow oil consumption, but it was amazing what it did in that rear end.
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 07-25-2010, 10:33 AM   #15
Davetopay
In my Mustang I used the Lucas Diff lube in the rear end and the Trak-Lock never once chattered, and it grabbed like a mofo. No wear issues either. I would drain it once a year for inspection and a general checkup as it was routinely launched a 5000+rpm with a side step of the clutch.
Davetopay is offline   Reply With Quote
