Old 07-25-2010, 12:17 AM   #1
trucks72
trucks72
trucks72's Avatar
How does a gas tank vent?
Not the 71-72 gas tank. The 67-70 tank. If you take a gas cap, turn it upside down so you are looking at the bottom of it. Blow on the center. It will not blow out. Now suck on it and air will come in. So when pressure builds in the tank where does it go?
trucks72 is offline   Reply With Quote
Old 07-25-2010, 08:16 AM   #2
Zeke
Active Member
Re: How does a gas tank vent?
Might be wrong but pretty sure it stays in the tank until you take the cap off, outside temp changes or use gas driving.
Even new cars don't vent to the outside that's why you get a woosh sometimes when you take the cap off. The canister on the 71-72 tanks and newer vehicles have canister to hold the gas vapor until it can be sucked in by the engine. The newer vehicles have a fill vent because when they went to unleaded gas they made the filler smaller to keep people from filling with leaded gas. Some gas stations have nozzles with contraptions, California, to suck up the fumes while filling up.
If you can blow both ways on a vented cap you probably need a new one.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 07-25-2010, 08:39 AM   #3
LONGHAIR
The "vent" is not there to let the pressure out....it allows air to come in to fill the space when the fuel is drawn out by the fuel pump. If it didn't, you would soon have a vacuum inside the tank. Once the vacuum level inside the tank got above the fuel pump's ability to pull......ya got nothin'. The engine won't run, or you have crushed the tank.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
