1999 Chevy
Sensor in dash
I have a 05 tahoe and the sensor for the auto lights has been pushed down in to the dash I was woundering how to pull that sensor out.
![]() Join Date: Sep 2005
Re: Sensor in dash
umm i think you have to pull the radio out and can reach up under the dash and push it back out
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
Re: Sensor in dash
pull the top instrument panel off and put the sensor back in the hole. remove the trim from around the i.c., both the a pillar garnish mouldings, the side panels from the dash, release the tabs for the passenger grab bar, accessed by taking out passenger side air vents, and remove. remove the screws fom the sides, and front of the upper panel, and lift panel off. reinsert sensor and reverse removal.
| Bookmarks |
