Anyone switched from a two piece DS to a one piece in a 69 swB with T-5 s-10 want to grab one ont of the bone yard on the cheap if possible then have it balanced and all new Ujoints then bolt in if possible. The truck is not lowerd it it stock minus the T-5 swap witch is great. Any help wood be a big help. Thanks guys
Re: want a 1 peice Drive shaft need help
Put the yoke in the trans, pull it back an inch or so, measure from it to the rear end yoke and head to the junkyard.
i have a 69swb with a 327 / t5 from a 84 camaro. lowered a bit , moved rear back 3/4" to center rear wheel. I have an aluminum shaft from a 2000? mustang gt , u joints fit , like it was made for it. Good luck - Bob
![]() Join Date: Jan 2008
If you can't find the exact length you need, you can get a little longer one and have it shortened a bit.
I did exactly like junkman said. Cost me $10 for the shaft. Don't worry sbout the yoke. Just look for the right U-joints and center to center distance. You can always swap the yoke from your old shaft as long as it isn't a 4 speed.
Ray Last edited by raycow; 07-29-2010 at 12:42 AM. |
