Old 07-25-2010, 04:22 PM   #1
TripleZ
A Arm 3"Drop spindle= problem
I installed the A arms from my 77 with bell tech 3" drop spindles on my 67. I hate to admit this but I thought I would put my 15 wheels back on just so I could get an idea of how the truck would look and be able to move it. The 15 inch rim hits the bottom arm. The rims I was thinking about using are the 16 inch Chevy rally wheels but I am not sure if they will fit without hitting the bottom A arm. If a 16 inch will fit I will but the rims and mount some old tires I have for now. Thanks for any input.
ZZZ
TripleZ is offline   Reply With Quote
Old 07-25-2010, 04:33 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: A Arm 3"Drop spindle= problem
This is normal.
Trim the a-arm around the lower ball joint.
They only cause problems with 15" wheels that have more than 3.5" of backspacing.
Ralleys have a 4" BS.
I've been doing this same mod since the early 1980's.
This is why there are 2.5" drop spindles.
Do they even make 16" 5-lug ralley wheels or do you have 6-lug rotors?
Keith
Convert to disc brakes.
Old 07-25-2010, 04:45 PM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
you may have a little grinding in you future..... or a spacer.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 07-26-2010, 12:40 AM   #4
TripleZ
I put 5 lug rotors and rear axles on the truck. I have always used Bell tech spindles and they do not come in 2.5, at least not from Summit. Oh Well looks like a little modification... no big deal. Thanks again.
Old 07-26-2010, 11:31 AM   #5
lolife99
lolife99's Avatar
I like using Belltechs 3" drop spindles as well.
Modifying the lower a-arm takes less than 5 minutes per side.
Some other brand spindles require you to grind in areas around the calipers.
Checking wheel clearance is a must for any drop spindle install.
Got any pics of your truck?
Keith
Old 07-26-2010, 04:57 PM   #6
charx2
charx2's Avatar
A spacer corrected this for me.
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 07-26-2010, 09:20 PM   #7
TripleZ
I do not have a picture of it in work.
