07-25-2010, 05:11 PM | #1 |
chevy 468ci gone bad. get it rebuilt or buy a crate engine
compression test confirmed my fears. cylinders 1,2,3,4,6,8 about 178-182 psi. cylinder #5 130psi. cylinder #7 90psi. I noticed a haze of oil or like a gas residue in the coolant the other day. any one know of a good engine builder?
07-25-2010, 07:33 PM | #2 |
Re: chevy 468ci gone bad. get it rebuilt or buy a crate engine
first you have cooling system problems, now you have low compression in two adjacent cylinders.
You have a blown head gasket. That is not too hard to fix, pull the left head, sand the block, plane the head, reassembly with Fel-pros best gasket. That's exactly what I have been doing today on my small block 400. good luck, justplainray |
07-25-2010, 08:10 PM | #3 |
I'm with Justplainray in that I would get that head off and see what went wrong. Most likely as he said, a blown head gasket.
Have the head checked out and surfaced and it should be fine when it goes back together. I would probably want to pull both heads and put a set of matching head gaskets back on it when I put it back together. Last edited by mr48chev; 07-25-2010 at 08:18 PM. |
07-27-2010, 09:55 AM | #4 |
right, like Mr48 said..
after sweating and swearing one head off on Sunday.
I'm pulling both heads, do it once, do it right. damn it was hot this past weekend. but this week's much cooler. justplainray |
