Old 07-25-2010, 06:16 PM   #1
69heavychevy
69heavychevy's Avatar
need some machine shop advise
I want to get some cylinder heads cleaned up. I want to take them to a machine shop and have them do it. Problem is i've never set foot in a machine shop and dont know what to ask for. Keep in mind all i need is to have them cleaned i.e. carbon build, chipped paint, dirty coolant passages ect. So what service do i ask for and how much should i expect to pay. i'm just trying not to get ripped off. thanks in advanced.
69heavychevy is offline   Reply With Quote
Old 07-25-2010, 06:29 PM   #2
Wrenchbender Ret
Re: need some machine shop advise
They call it Hot Tanked. They put them in a heated caustic solution overnight & it removes everything. Paint, rust, carbon & sludge. I don't know what it costs any more as I havn't had any done for a long time.
Wrenchbender Ret is offline   Reply With Quote
Old 07-25-2010, 06:42 PM   #3
Davetopay
There's a ton of other little things to have done as well. You can have them surfaced, check the valve guide clearance, clean up the valve seats....let us know more about the heads and we can give you some more specific pointers.
Davetopay is offline   Reply With Quote
Old 07-25-2010, 06:45 PM   #4
beautimus
beautimus's Avatar
Keep in mind that hot tanking a set of heads WILL eat up the rubber valve stem seals. So, you will want to have new seals put in. their not expensive, and this is a good time to go ahead and have new ones installed anyway.
The reason i am saying this is so you will know that the machine shop guys aren't trying to rip you off if they suggest putting seals in. oh, there are several types of valve seals, if your heads will accept the umbrella seals they are much better than the o ring type.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 07-25-2010, 07:07 PM   #5
vectorit
What?
vectorit's Avatar
I suggest just going in with your heads and ask about getting them rebuilt.
You may think about buying a set of valve springs from your favorite brand, and bring them in along with your heads. A lot of times they will just replace whats needed, reusing what you have and grabbing a used tested good spring from their stock. This isn't ripping you off or anything, it's just the shop trying to save you cash. Bringing in a set of springs, most of my experience has been that they like that. Since it makes the job quicker for them, meaning they don't have to worry about your old springs.
Ask about package deals, since they usually save you money. Going ala carte on things can be more expensive for you in the long run.
Cleaning them is typically standard.
Have them magnafluxed to check for cracks.
Make sure they are set up for unleaded fuel, if not have hardened seats installed.
That's pretty much the standard on getting heads done in my experience.
Also, I like to mark my cylinder heads with my initials. That way I get back my set that I brought in, and not some other persons set that may have something different about them from mine.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-25-2010, 07:44 PM   #6
69heavychevy
the heads are 906 vortecs that came of a wrecked 96 yukon with 100k on the odometer. the heads themselves are pretty clean, just minimal carbon build up, nothing a wire brush wont take care of. but if i can them cleaned for around $20-30 then i then id rather do that and save myself some agony in the texas heat.
Old 07-25-2010, 08:49 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
with 100k...if you're going to have them off...there's no reason NOT to go ahead and have a valve job done. This will get your valves checked and faced, and your seats checked out and cut, along with your spring pressures checked out and new valve seals. They'll also check your guides as part of the work...and you'll get the VAT job done on them w/o asking as its part of the valve job...as is a coat of paint.
Well...at least when I was rebuilding heads in the late 70's it was that way.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
