Old 07-26-2010, 03:52 PM   #1
62much
62much's Avatar
Weight in or under the bed?
This may seem like a dumb question, But it's not my first
Has anyone put some kind of a weight, lead, steel, large child, anything, in the bed or under the bed to lower the back down a little? I went to get a 1/2 yard of Bark Dust the other day, and the truck sure rode a lot smoother with a small load, stance looked better! I was thinking about welding, strapping something under the bed to add a little weight without it looking to bad, or I could just drive around with a load of rocks... but that just wouldn't look good, especially at cruise-ins. Anybody done anything like this?
62much is offline   Reply With Quote
Old 07-26-2010, 03:54 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: Weight in or under the bed?
I would change the springs or install airbags to soften your ride and get the stance you want.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 07-26-2010, 04:07 PM   #3
62much
62much's Avatar
Airbags might be the ticket. Do they make aftermarket springs that are softer than OE? I know they make lowering springs.
Old 07-26-2010, 04:25 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I didn't want to lower my truck, but I wanted a much softer ride so I was going to install a steel diamond plate floor over the aluminum version I already have. I figured after painting it nobody would really know the difference.
While waiting to do that I discovered the Jeep lowering springs, but again didn't want the truck lowered, so I picked up a pair of Jeep 2.5" lifting springs off eBay for about $65. The truck now rides just a tad lower than it did before, but rides like a Buick. I don't imagine it will haul much of a load, but I almost never carry heavy stuff in it anyway.
Old 07-26-2010, 05:36 PM   #5
62much
62much's Avatar
Damn site keeps logging me out every 5 minutes, anyway... maybe a heavy sheet of metal and some sand bags might work, just need a few hundred pounds or so! Heck, maybe I'll just pay my 15 year old to ride in the back whenever I go somewhere. He weighs at least 120lbs. and ALWAYS NEEDS MONEY
Old 07-26-2010, 08:43 PM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I put a couple hundred pounds of sand over the axle for winter... does look better, and rides a little nicer...
Old 07-26-2010, 10:55 PM   #7
TheDark1
Intentionally Left Blank
TheDark1's Avatar
I had 2 peices of railroad track in mine for years. Each one weighed 88#. I did it mostly for traction, but I took them out when I put the fuel cell in the bed.
They were slightly narrower than the frame width. I cut notches in the ends and a hole in the middle about 1" in diameter with a torch. The notches fit in between the frame rails from side to side and then I ran a piece of all threaded rod through the holes and through the last two cross members. Double jam nuts on each side of steel and cross members and in 17 years they never moved or rattled. I couldn't say if it lowered it any since, at that time, the springs were shot, but it rode pretty good.--Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 07-26-2010, 11:50 PM   #8
bubba327
HOW long until spring??
bubba327's Avatar
Only trouble with excess weight - it affects fuel mileage and acceleration.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 07-27-2010, 12:08 AM   #9
hotrodhomi
hotrodhomi's Avatar
Don't forget stopping and turning
Why not move your fuel tank between the bed rails?
'66 impala ht
Old 07-27-2010, 08:13 AM   #10
lakeroadster
And if it isn't properly secured it becomes a projectile in an accident or during drastic manuevers.
Learned this one the hard way: I would use sandbags in the winter made from a burlap horse feed bag. I placed (1) behind each wheel tub in my S-15 pick-up and they stayed in place great. Then the moisture in the sand froze, and I had a boulder wrapped in a burlap feed bag! Was going around a sharp curve when the frozen bag broke loose from the bed liner.
I thought I had been hit by a mortar! Luckily the bed liner took the hit without any visible damage.
Just something to think about.
lakeroadster is offline   Reply With Quote
Old 07-27-2010, 06:01 PM   #11
bubba327
bubba327's Avatar
Reminds me of an old horseshoer friend here in the valley who used to carry his shoeing anvil loose in the bed of his truck.
Well, one frosty morning he hit the brakes a little strong and stuck the horn of that anvil through the passenger side of the bench seat in the cab of his International pick-up.
An object in motion... tends to stay in motion...
Old 07-28-2010, 10:38 AM   #12
Malibob
Malibob's Avatar
In my '51 Chev coupe I used a bunch of sand bags workked great too. Then one day I spilled a ton of oil and had to use it all. It was simple play sand and soaked it right up.
Maybe I should have told BP about that months ago.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
