Old 07-26-2010, 04:35 PM   #1
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
swapping mid 80's front end into my 68?
Hear lots of people do this, why? what all is involved? is it worth the headache? thanks
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 07-26-2010, 07:18 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: swapping mid 80's front end into my 68?
It gives you the benefit of disc brakes and 5 lug if you keep the stock rotors. Replacement parts are much cheaper too. It's a fairly straightforward swap.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-26-2010, 07:43 PM   #3
tantrumpipeline
i tried searching the site and havent found anything, possibly using the wrong titles, is this swap done using the entire front end or just partial? you wouldnt have any links would you? This would be cheaper than going through cpp for everything and be quite easy since my truck will be down to the frame by weeks end or am i easier off buying everything? going to buy all new wear parts, ball joints/ sleeves, tie rods etc for safety and driveablilty regardless
20 Duramax tow pig
52 short project
Old 07-26-2010, 07:53 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's 40 threads from just one description in the search box.
Put in disc brake conversion and you will get more.
http://67-72chevytrucks.com/vboard/s...archid=1791371
Keith
Convert to disc brakes.
Old 07-27-2010, 01:34 AM   #5
tantrumpipeline
thanks i wil have a look, the disc part wasn't all that important as I had planned a CPP disc conversion all around, but the links you put forward I'm sure will have the info I am looking for, never even thought to put that in, thanks for the help, getting pumped to get going on my build again, looks like I finally found a cab that's worth fixing.
20 Duramax tow pig
52 short project
Old 07-27-2010, 02:04 AM   #6
tantrumpipeline
more so looking as to what parts are involved, a arms, ball joints, drag link,tie rods, etc what is swapped out and what is kept to be rebuilt.
20 Duramax tow pig
52 short project
Old 07-27-2010, 09:08 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
You can go as compl;ete as swapping the entire crossmember, or just do the A-arms out. You can do just spindles too, but you will need to change ball joints.
Articles-
"Refining Sierra"
Old 07-27-2010, 12:50 PM   #8
tantrumpipeline
thanks I will be on the lookout at the wrecking yard today, looked a few different searches up and found what I need, thanks for the help guys.
20 Duramax tow pig
52 short project
Old 07-27-2010, 02:57 PM   #9
RocketKing
RocketKing's Avatar
Don't forget while you are looking that you can use all the way up to '91 year model if it is a suburban. They did not change the body style like the trucks did after '87. However the rotors will be the heavier 1.25" instead of the regular 1".
I used the entire crossmember from an '89 burb and I only had to drill two holes and widen two, the rest of that sucker just bolted up. Take a look on my build thread if you want.
Rex
RocketKing is offline   Reply With Quote
Old 07-27-2010, 03:17 PM   #10
tantrumpipeline
Thanks, looks like quite the build, nice work, eathers been too nice here, been at the lake too much to start back into mine, but I think it's time
20 Duramax tow pig
52 short project
