Old 07-26-2010, 11:24 PM   #1
JCA1972
JCA1972's Avatar
Weekend Gauge project.
I changed out my volt, oil and temp gauges this weekend, I went with the Sunpro brand, I also installed an RPM gauge.
The truck was running when I took the Pics.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 07-26-2010, 11:33 PM   #2
tonypaul
tonypaul's Avatar
Re: Weekend Gauge project.
Looks great! The PO of my truck used the same sun-pro tach and put it in the same place, but he didnt do near as good as job as you.
Keep up the great work!
tonypaul is offline   Reply With Quote
Old 07-31-2010, 07:22 PM   #3
350votec72c10
Ive go the same tack also, Looks slick and fits like it was made to go there, id like more info on your other gauges please.
350votec72c10 is offline   Reply With Quote
Old 08-01-2010, 10:08 AM   #4
kq4pc
messup up on post
36 master 36 master delux coupe,6cly,3sp. 58 impala,348 3 duces,4 sp. 56 belair,302,4sp,12 bolt. 2000 silverado,5.3 auto. 65 foo foo rd,352 auto,for sale
kq4pc is offline   Reply With Quote
Old 08-01-2010, 10:10 AM   #5
kq4pc
Talking Re: Weekend Gauge project.
Hey JCA1972 Got a question about pulling the guage bazel.do you have to drop the steering colum to get bazel off?i just picked up a 68 short step side,and po had bought one and never installed. thanks Bobby
Old 08-01-2010, 10:20 AM   #6
71GMCinTN
Not to jump in on a question for someone else, but I did have to drop my steering column.
71GMCinTN is offline   Reply With Quote
Old 08-01-2010, 10:59 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice upgrade I just did my lowers with autometers...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-01-2010, 11:31 AM   #8
BIG ORANGE
BIG ORANGE's Avatar
Nicely done, I like it!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-01-2010, 02:30 PM   #9
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Nope, just the bracket that holds the steering column gromett and then the screws around the benzel. Also need to pull the cable, oil pressure line and unplug the wiring.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-01-2010, 03:12 PM   #10
dan42
dan42's Avatar
I'm gonna do that too - how long did it take you? did you re-wire it, or did you use the existing wiring? Looks really nice.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-01-2010, 04:22 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
non tach panels will come out with some work, but loosening the column at the top will help. Tach panels need to be loosened though. I normally remove the nut on one side of the column but not on the other. Drops it enough without flopping it into your lap.
Old 08-29-2010, 11:37 AM   #12
JCA1972
JCA1972's Avatar
I used all the new wires that came with the gauges it was easier than i tought. the hardest part was cuting the holes on the plexi glass, it breaks pretty easy. you can do it in a few hours.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 08-29-2010, 11:41 AM   #13
JCA1972
JCA1972's Avatar
You shouldnt have to but it helps if you drop it a little, I had to drop mine because I have my steering coulmn pushed in about 3".
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
