![]() Join Date: Dec 2008
DJM 3" spindles and 15" wheels
I have 15" corvette rally wheels in 5x5 pattern and installed DJM 3" drop spindles. I have a clearance issue with the top caliper mount. It rubs the inside of the wheel. Has anyone else had a similar problem? Can it be ground down just a bit or do you need larger rims?
Re: DJM 3" spindles and 15" wheels
Grounding down will fix it no problem.
i had the same problen on my truck!i just took a good ol' grinder and made it fit!!and a wheel spacer!!bt yes bigger rimms are the way to go!!
I've had to grind down the top of all the DJM spindles I've used. Take a little off at a time until the wheel fits. It won't hurt a thing.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
I'll give it a try later tonight. Thanks for the input.
I am using a 15x6 wheel in the front will this interfere with a drop spindle?
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
I ground it until I didn't feel comfortable. So I got some 20's on craigslist. problems solved. I just told the wife that I needed new wheels to make my truck work...
Sorry to di, but anyone have pics on how far they went?
There's plenty of material to grind. I can't believe you don't have a clearance issue with the lower a-arm, or maybe you just haven't found it yet.
chevy runs deep
post pics when done
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
I keep hearing everyone talking about the lower a arm clearance with dropping these trucks. I've lowered 4 of them with djm spindles and different drop coils with multiple 15x 7 and 15 x8 Inch wheels and never ran into this problem. I have had to grind some meat off them to clear a wack set of aluminum wheels though.
Posted via Mobile Device |
#13 |
6.0 powered square
My 7" cragar stars with 4 1/8 bs didn't have any trouble with 3" spindles, but when added wilwood d-52 calipers I had all kinds of problems so now I will be running 15x7 88-98 steel wheels for now till I can afford some 17 or 18 TT2s
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#14 | |
I have a truck with litterally no front suspension, so still trying to piece it together, research, to avoid any issues this weekend |
#15 | |
#16 | |
![]() Join Date: Jan 2010
I would like to see some pictures of your truck after you lower it. I have the same wheels to put on after I lower it. At least until I can save up for 20's. Curious what it looks like. |
#17 |
What tubular arms are those? Dont see them in google. How much were they? Cheapest I've seen are like $400!
'87 R10 - 5.3, 4.8 Flat Top Pistons, 220r Cam, Long Tubes, P&P 862 Heads, 4L80e '84 C10 - 5.3, LS6 Cam, 4L80E, 3.73, Ported Heads 329hp/334tq !! STOLEN !! 2-15-13 North AL Click Here:How To DIY Port & Polish LSx Heads Videso by "AGearHead4Life" |
#18 | |
Happy to be here
![]() Join Date: Mar 2000
1973-1987 Chevy C10 - StrongArms Front Upper-$400.00 ![]() 1973-1987 Chevy C10 - StrongArms Front Lower-$600.00 ![]()
