Old 07-27-2010, 04:04 AM   #1
Jeffs68
Jeffs68's Avatar
Exclamation tips and tricks
any one out there have any tips n trick to sled pullin i have a 68 k 20 with the 4 speed granny low i belive a 307 and 4.56 gears i want to pull at the fair this year but..... i dont know any tricks about sled pulling
Jeffs68 is offline   Reply With Quote
Old 07-27-2010, 05:00 AM   #2
prairewolf
Re: tips and tricks
Just an .02 cents worth observation from the Grandstands. .... Highest Rpms you can get and stay in Low gear for a while..... and have your Veh. super clean. you only get one chance to make a 1st impression.
eat,work,spend,sleep,repeat.
prairewolf is offline   Reply With Quote
Old 07-27-2010, 06:48 AM   #3
292farmer
292farmer's Avatar
Re: tips and tricks
traction, is a major key, is yours the sm465? if so id put the transfer case in 4lo and actually start off in second, and keep it in second. granny has a great ratio however u really cant get much speed out of it with a 6.57L and 4.57 axle. and your going to want some speed to throw dirt and get some momentum. plus 4l is roughly a 2:1 ratio so makes 2nd close to 1st again. i wouldnt try going into 3rd even if your going good, as these tranny dont like speed shifting and u have to shift fast and hard other wise u lose your momentum quick(not good), and might damage it. also make sure your clutch is in good order, and expect that to smell like hell for next day or so, as that will put extreme heat and slip on it, wouldnt be surprised u break a ujoint either so maybe bring an extra? make sure all fluids are good and full(axle tranny motor) good luck!!
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 07-27-2010, 01:18 PM   #4
Jeffs68
Jeffs68's Avatar
Re: tips and tricks
thanks guys! im not for sure about anything with this truck i have to pull numbers off the motor to find out for sure if it is a 307 but i do know it was built in canada so i think thats why my hubs look so goofy haha. ill probably have the girlfriend take a vid with her camera and ill put a link up for you guys
oh and i can pull a 84 4 door long box 2wd 6.2 chevy with all wheels locked up in 1st and 4lo i tryed 2nd n 4lo and the clutch didnt like it so much haha
Old 07-27-2010, 05:19 PM   #5
292farmer
292farmer's Avatar
Re: tips and tricks
if your clutch didn't like it in 2nd i'd say stick with 1st then, i just don't like using 1st to much because as bombproof the sm465 is they hate spinning super fast in granny both my buddies blew their granny out pulling. my dad always used second as that gear seemed to handle the hi revs better.
also check the rules as some require a kill switch on truck that mounts/attaches to the sled for emergencies.
Old 07-27-2010, 07:48 PM   #6
Jeffs68
Jeffs68's Avatar
Re: tips and tricks
Yeah I'm going to try to take second before the 75 foot mark cuz then I I screw up I can rehook haha
Old 07-27-2010, 08:50 PM   #7
Davetopay
Re: tips and tricks
Make sure to read the rules carefully.
If you want to pull around here you need drive shaft loops, u joint scatter guards, a tranny blanket/scatter shield, all kinds of crap a regular street truck doesn't have. I'd hate to see you pay all the money to enter and then not pass tech.
and with 4.56 axles, I'd put the tranny in 2nd and t-case in 4Lo and work with a steady and gentle foot. Also, check into what kind of ballast weight you ar allowed to use and how it can be mounted. If your truck tips the scales at 4300 pounds and the class limit is 6500, there is a real traction advantage to be gained by weighting the truck.
Davetopay is offline   Reply With Quote
