Old 07-27-2010, 12:54 PM   #1
jmanthony65
jmanthony65's Avatar
Ball joints...
Ok.. So i've got a stupid question.. How tight are the nuts on the ball joints suppossed to be? Should the spindle rotate on the ball joint or with them?
jmanthony65 is offline   Reply With Quote
Old 07-27-2010, 01:33 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Ball joints...
Torque specs for C10,
Upper ball joint 70
Lower ball joint 120
The ball joint stud should rotate with the spindle. Make sure you have the correct matching ball joint/spindles so the tapers match (i.e. '62-'70 ball joints with same year spindles, '71-'72 BJ/Spindles or '73-'87 BJ/Spindles).
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-27-2010, 02:09 PM   #3
jmanthony65
Re: Ball joints...
That's what i thought... Just making sure.. Thank you..
