Old 07-27-2010, 02:58 PM   #1
iroc12valve
4l80 - t400 np205
I have a 1991 gmc v3500 OBS right now its got a 4l80 up to a 205,
the 4l80 isn't right and needs a rebuild. (1300 using stock converter)
what i want to do is just put in a TH400 but i still want to have the 205, I have heard that 2wd 400 has a 32 spline output, and my 205 is 32 spline input . Is there something i'm missing (e.g. male/female shafts etc.)
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 07-27-2010, 07:01 PM   #2
65ChevyUtah
Re: 4l80 - t400 np205
Yes you are correct the 2wd Th400 has 32 splines. I used a 2wd th400 last year and hooked it up to my 205 transfer case and worked out great. I had a two wheel drive truck and I switched to a 4x4 frame using the same transmission. You need to make sure you have the th400 to 205 adapter. I am not a transmission expert but why not just rebuild the 4l80 ?
65ChevyUtah is offline   Reply With Quote
Old 07-27-2010, 08:59 PM   #3
iroc12valve
Thanks for the info,
I'm not doing the 4l80 right now because 1300 is a little outta the budget and thats for a stock rebuild with the stock converter. it would be about 2500 to build a bullet proof one with a good converter, plus they're known for solenoid problems.
and some K5's lol
Old 07-27-2010, 09:00 PM   #4
iroc12valve
does anybody know if the adapter from my 4l80 would fit with a 2wd 400 ? to keep the 205
and some K5's lol
Old 08-03-2010, 01:38 AM   #5
64swb
64swb's Avatar
to bolt up to a th400 with your transfer case/adapter you would need a 4x4 th400 that had either a np208 or later model 205 (like yours) behind it. the 2wd th400 will only bolt up to a 205 with the older figure 8 short style adapter. yours should be the later model long round pattern adapter. the output shaft on the later th400s for 4x4 are longer than the old style. iirc it was somewhere around the early 80s when they changed the styles of the adapters.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 08-04-2010, 01:50 PM   #6
raycow
Maybe you need to research this first and find out what the all-up cost will be. If you have to buy a TH400 core and get it rebuilt, and then add the cost of the adaptor parts, I can see it easily reaching $1300. And after all that, you would still be giving up the overdrive and lockup converter.
Ray
raycow is offline   Reply With Quote
Old 08-04-2010, 03:18 PM   #7
iroc12valve
I can have a good 400 for $ 200 and i figured that if i can re-use my current 205 adapter then i would just need to lengthen my rear shaft( its a 2pc carrier bearing) i have other front shaft's so that wouldn't be a problem.
and some K5's lol
