64-66 dynacorn doors
Has anyone used the dynacorn 64-66 replacement doors and how did they fit. I noticed Alan used the goodmark doors on the Project Vitamin C-10 build and they seem to fit good. I wonder are they all made by the same manufacturer.
Also i am new here and i have a 1966 lwb stepside i've had for 26 years. Due to circumstances and neglect its been sitting for 12 years. I just started to rebuild it and will post a build thread with pictures. There are a lot of nice trucks and talented people here. |
1961 crewcab
Re: 64-66 dynacorn doors
I think dynacorn and goodmark are one and the same...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thanks for reply. I wonder if all the doors are from the same manufacturer, maybe triplus.
The Few, The Proud
![]() Join Date: Jun 2007
According to a Goodmark rep that I spoke with recently, they have their own dies and stamp all of their own sheetmetal. He felt inclined to tell me this after I complained to him that his prices were $100-$175 more for the same items from Tri-Plus.
Shannon |
Thanks for the reply, I'll have to check into this farther. The reason i am looking at dynacorn doors is because there is a local dynacorn dealer and if i bought goodmark doors the truck shipping to canada would make the doors quite a bit more expensive than dynacorn.
60-66 Nut
![]() ![]() Join Date: Mar 2007
I wasn't aware that Dynacorn was making '64-'66 doors. I've not used any of their products, but what I've seen of their repro '69 Camaro bodies they looked good. The owner seems to be a stand up and knowledgeable guy if that counts.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-28-2010 at 12:01 AM. |
Mine did not line up perfectly. The trim line under the window opening is much less pronounced and it was a pain to hang. All the adjustments are behind the cowl.
Aligning it just right is an art, not an art the they studied at the factory either (apparently). I was all bummed that the new door didn't align perfectly that I hung. Then I went over to the driver's side and I thought I must have been an expert. Comparitively of course.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
I suppose what ever aftermarket door i use will need a little tweaking, thanks for the input.
