Old 07-27-2010, 08:14 PM   #1
NZSquare
NZSquare's Avatar
Do I need drop spindles ?
Hi all,
Im running a 1.5" sectioned crossmember with bags and dodge 20's, I've got the truck sitting where I want it height wise without spindles but have a set of 2.5" dropped ones I can put in.
SO, do I need them?, I need as much lift as I can get due to having a steep driveway. I don't need to go any lower really and I kind of like the camber look when aired out and the way it tucks the tire up into the engine bay out of the way.
I typically drive the thing with 80-90 psi up front with 2600 bags, at this height am I likely to see accelerated tire wear ? Its the only real reason why Id be going to spindles at this stage. Any input ?
thanks
heres the truck in question
NZSquare is offline   Reply With Quote
Old 07-27-2010, 08:44 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Do I need drop spindles ?
No, it doesn't sound like you "need" them. All that would do is allow you to run lower. We do need to see more pics though.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
