07-28-2010, 12:04 AM | #1 |
gm ac compressor to sanden swap?
I have another rebuilt crapped out pancake style compressor... maybe its an a-4.. cant remember) on my 81 chev.
Its a 305 with factory power steering and ac on the left side of the engine. only other accessory is the alternator. ** question: Has anyone swapped the gm compressor for a sanden unit? (brand new 175.00 or so everywhere and last forever as opposed to the yearly replacement of my other type!) What has worked for everyone? I'm not interested in a march pulley system or anything. Fine with keeping the v belt, too. I know i would have to modify the hoses... will probably try to crimp new ends on the existing (new) manifold hose and keep everything else gm... (drier, orifice,etc) |
07-28-2010, 10:27 AM | #2 |
Happy to be here
Re: gm ac compressor to sanden swap?
We did it on my Ramjet 350 install, but I used a complete set of aftermarket brackets. Probably not what your looking for.
07-28-2010, 05:26 PM | #3 |
I used a a/c bracket made by alan grove and had new hoses made by local street rod shop. that was about another 150 plus the sandon. The biggest pain was that I bought and returned a dozen v belts till I found one that was the right length.
'79' shortbed |
07-28-2010, 05:29 PM | #4 |
So are there any direct bolt-in replacements options for compressors?
I have a 78 silverado with the factory compressor and it really bogs down the truck. I'm betting its going to die in the near future (very old). I would love to find something I can just unbolt the old one and bolt in a new one...?
78 Silverado 1/2 Ton LWB (restore) 78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse) My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128 Ellis Benus - Web Design Columbia Mo & Google Fan Boy! |
07-28-2010, 05:39 PM | #5 |
Insert Witty Text Here
AFAIK, here is nothing that simple.
I went through a couple of rebuilt R4s before deciding to buy a new one. It cost me as much as 3 rebuilts, but 6 years later, it is still going. I figure it has paid for itself since the rebuilt units were lasting one summer each, and I have saved myself from breaking the system open, flushing, and vacuuming 5 or 6 times. When this one goes out, I'm going with an Alan Grove bracket and a sanden just like DubDubU. A friend went that route on his V8 S10, and it worked out really well. He also reports that it draws less horsepower. Slonaker |
07-28-2010, 09:11 PM | #6 |
Is there a web site for this unit?
07-28-2010, 09:59 PM | #7 |
Happy to be here
07-28-2010, 10:19 PM | #8 | |
Frank
Born and proudly residing in a Red State ! |
07-28-2010, 10:56 PM | #9 |
Dub, thanks. do you have all of the other original brackets, or a system?
*** Slonaker, thanks. r4 is what I was searching for.. yeah this recon is number 2 BTW.... AFAIK? *** cmon f.monroe... whats the bolt in for my r4? (: **** thanks for all the reply's fellas! |
07-28-2010, 11:40 PM | #10 |
Glad to help out, all my other brackets are stock.
'79' shortbed |
07-29-2010, 01:05 AM | #11 |
found a "new" r4 here. 241.00 aint too hurtful..
*** https://www.ackits.com/pc/20-10403--...ssor++-+Clutch *** I think i found the bracket you must have used: http://www.alangrovecomponents.com/S..._Long_Pump.htm part 119L - ac cost is 87.50 |
07-29-2010, 09:51 AM | #12 |
Alan Grove's brackets are really nice. They are well designed, and have beautiful welds on them. I plan to get a bracket from them for my '37. I have heard that Vintage Air uses their brackets, or did at one time.
Slonaker |
07-29-2010, 02:34 PM | #13 |
On a budget like Fred Sanford
Last I knew they still do. Depending on the cost of having new hoses made, I may do the swap next spring. Brand new sanden 508 compressors are going on ebay for the same money that a rebuilt R4 costs......
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
08-09-2010, 08:42 AM | #14 |
check this out!
no need for making new hoses. you can get a GM manifold for the back of the sanden: http://www.nostalgicairparts.com/air...ad-back-16.php |
08-09-2010, 09:27 AM | #15 |
IT Guy/ Father/ Chevy lover
what is the part number for the compressor for our trucks, I've been looking into replacing my compressor and if this sanden holds up half as well as everyone is saying they do it would be worth the investment. just incase you would need it 78 350
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
08-19-2010, 06:12 PM | #16 | |
09-07-2010, 12:24 PM | #17 |
If you are looking to replace a R4 compressor with a Sanden Unit, you can use a set of brackets from Vintage Air. I just used this to put a sanden in a factory serpentine setup off of a 95 truck. It's part # 141805. I can take a couple of pics of it when I get home if you would like.
http://www.vintageair.com/catalog10/...Page%2065).pdf
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 09-07-2010 at 12:53 PM. |
10-23-2011, 02:04 AM | #18 |
motor exploder
I know this is an old thread, but smbrouss70 - I'm looking at doing the same thing, but with the serpentine setup from an '89 454. Can you still get a pic of that bracket?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-23-2011, 02:05 PM | #19 |
I replied to your PM also, but I'll post my mock-up pics for everyone's benefit.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
05-13-2012, 03:41 AM | #20 |
Digging up an old thread....
Hey guys, are you running the rest of the GM designed A/C parts? Is the system running as well as stock? Better/worse? I ask because I bought a Sanden 508 and Kwik Performance bracket for my '86 K5. I went to a local A/C shop with the truck and had custom hoses made. As I was paying for the hoses the guy decides to say, "You know that Sanden 508 isn't big enough for the factory GM evap, right?". I wasn't too happy he is telling me this after I just spent $100+ on custom hoses. So I am curious to hear what you Sanden conversion guys have to say. Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
05-30-2012, 07:30 PM | #21 |
Can anyone can speak of this conversion? Like said earlier? any better? Seems like you replace these r4 pancakes about as often as you flip them making morning breakfeast.
My 95 3/4 ton needs an ac compressor and thought I' d like to make it better than before.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
05-30-2012, 10:37 PM | #22 |
I'm researching info on this as well.... If anyone knows the answers or has any additional info, please do contribute!
05-30-2012, 10:49 PM | #23 |
http://67-72chevytrucks.com/vboard/s...d.php?t=524353
05-30-2012, 11:03 PM | #24 |
Any idea what this bracket from Vintage Air costs? I was going to build my own (Kwik Performance has directions how to build some that will fit in the 88-98ish brackets) but it would be nice to just buy some if they did not cost a lot.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
05-30-2012, 11:09 PM | #25 | |
Plus the LSx Vintage brackets costs the same as the Kwik Performance brackets because they are Kwik Performance brackets with a Vintage sticker placed over the the Kwik Performance sticker. Even the instructions are Kwik Performances. I bought mine through Summit Racing already knowing this since Summit carries Vintage Air, not Kwik Performance.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 05-30-2012 at 11:37 PM. |
