Old 07-28-2010, 12:52 AM   #1
reds_racing
ECE install help???
I got the front done and a I have looked at Lolife's post about trimming the a-arm due to 15" rally wheels, however several others state it isn't needed. But mine are awfully close to the wheel. Look at the pic and tell me if I need too. Will it get closer when I set the truck on the ground? I have about a 1/4 inch clearance right now!
reds_racing is offline   Reply With Quote
Old 07-28-2010, 01:18 AM   #2
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: ECE install help???
I'm pretty sure you will need to... Any spindles I have installed with 15" rally wheels required the A-Arm to be trimmed. It isn't the bottom that needs to be trimmed... It's the bottom part of the front and back edges. Turn the wheels to full "lock" and spin the wheel and tire. You will probably find that it grinds on the arm in the places I mentioned.
Oh, I forgot to mention... Before you spin the wheel too hard, watch out for your wheel weights, the control arm will probably catch them and pull them off. Not sure if your wheels and tires are balanced but it might be a PITA if you knock them off.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 07-28-2010, 01:25 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
X2^.
Jump up and down on the front bumper with the wheels turned left,... and then right.
You will see the need to trim.
Also look for clearance issues between the a-arm and any wheel weights.
What drop spring did you use?
You need to look at the bumpstops and make sure there is enough room between them and the crossmember to allow for a good ride.
You may need to trim the rubber bumpstop shorter, or remove it totally.
Keith
Convert to disc brakes.
Old 07-28-2010, 10:12 AM   #4
pat 70/71
pat 70/71's Avatar
I run ece drop spindles on both my trucks one has 17" tt2s and one has 15" rallys . I have no problems with rubbing at all. cheers, Pat
pat 70/71 is offline   Reply With Quote
