Resident Lurker
Edelbrock Fuel Pump Clearance Problem (pic)
I swapped an I6 for a 350 recently. The new engine came with an Edelbrock fuel pump installed. I had to remove the fuel line fitting from the pump when I dropped the engine in because it was hitting the engine tower. Well, I re-installed the fitting tonight, but it's so tight between the tower and fitting that I can't get the hose installed. I could use a 90 fitting, but I'm almost positive the pump is too close to the tower to screw it on. Has anyone else had this or a similar problem before?
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252 "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken |
Re: Edelbrock Fuel Pump Clearance Problem (pic)
have you tried rotating the housing? I had to on mine to get the discharge where I wanted it. Those pumps can be rotated 360.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
X2
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
"THE GREEN GOBLIN"
What Motor mount towers are you useing I6 or 350, That could cause a problem too?
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Resident Lurker
Thanks! I noticed the fasteners all around the perimeter and wondered if that would allow it to be rotated, but wasn't sure. I'll disassemble/reassemble tonight after work. Thanks again.
