Old 07-28-2010, 12:03 PM   #1
hoodup
hoodup's Avatar
Pics of where the best place to install a temp gauge on a 350?
Is there a more accurate place to put the prob for a temp gauge on sb 350?
Just cause my Hood is up every weekend doesn't mean its broke down!!
hoodup is offline   Reply With Quote
Old 07-28-2010, 12:15 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Pics of where the best place to install a temp gauge on a 350?
I have mine in the driver's side head.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-28-2010, 12:17 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
Mine is in the driver's side head. Also the '92 454 has it in the driver's side head.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-28-2010, 12:23 PM   #4
johnechi
johnechi's Avatar
Yep, driver side head.
johnechi is offline   Reply With Quote
Old 07-28-2010, 12:23 PM   #5
Lee H
Lee H's Avatar
Mines in the intake next to the thermo housing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-28-2010, 02:28 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
What's the difference in temperature readings between these 2 areas?
(not meaning to hijack the thread)
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 07-28-2010, 02:28 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Drivers side head is where the stock location is. That's where mine is.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-28-2010, 02:38 PM   #8
storm9c1
*** That's interesting ***
storm9c1's Avatar
+1 on the driver's side head for a normal flow Chevy V8 engine. On a reverse flow engine (like the 90s LT1), it went on the passenger side head.
You can also put it in the water pump or intake bung as others suggested. You might get a more consistent reading there since the heads do heat soak (and sometimes cars with EFI use two different sensors for this reason). If you are using EFI, and need a probe for the computer, I'd say use the WP or intake. If you are hooking up a gauge, I'd say put it in the head. A head will heat up very fast if there is a cooling issue and it will also show up on the gauge faster to warn you.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 07-28-2010, 02:54 PM   #9
hoodup
hoodup's Avatar
i have a gen one 350 with headers, the prob is on the pass side of the truck and i dont think the reading is accurate...is it more accurate to have on driver side or water pump bung?
Old 07-29-2010, 01:19 AM   #10
raycow
It wasn't always. Earlier engines had it in the intake manfold near the thermostat housing, and that's where I like to put mine.
Ray
raycow is offline   Reply With Quote
Old 07-29-2010, 01:23 AM   #11
raycow
Any threaded port in the water pump is on the cold side of the system. You will be measuring the temp of the water coming back from the radiator.
Ray
Old 07-29-2010, 02:28 AM   #12
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Not to High jack this thread but What's the difference of a reverse flow engine vs regular flow, Just curious because my 72 truck with a 78-90, 454BB has it on the passenger side? I am just kinda curious as I will be adding another after market water temp gauge and was thinking of putting it in the intake manifold or driver side head.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-29-2010, 02:16 PM   #13
storm9c1
storm9c1's Avatar
Reverse flow is only applicable to the '92-97 Corvette (and '94-96 B/D-Body) LT1 engine. On these motors, the WP was driven from the cam, and it pushed water through the heads first. It's actually a neat system. There are lots of details online about this, one link being: http://sstilletto.tripod.com/sstilletto/id11.html
Though now that I think about it, I'm not sure it matters which side head you put the temp sensor on.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 07-30-2010, 10:43 PM   #14
petey-pablo
"THE GREEN GOBLIN"
Thanks for the info.
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 06-12-2011, 07:34 PM   #15
madchopper
If my heads not have the ports to install the temp guage and now I am going to use the port on the intake, next 2 the thermostate for an eletric fan where can I put he probe for mecahnical temp guage. Or since the eletric fan has two probes can i split one to hook up a eletric temp guage.
madchopper is offline   Reply With Quote
Old 08-02-2011, 08:21 PM   #16
CEE1NG_RED
Any pics to point it out?? Thanks.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 08-02-2011, 09:02 PM   #17
Hubscrub
Cruzin
Hubscrub's Avatar
here's where in the drivers head
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-02-2011, 10:23 PM   #18
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
in the head, left or right, is the best place to put it.
If hooking a fan controller, in the rad is the best place for it.
Old 08-03-2011, 06:47 PM   #19
CEE1NG_RED
Water temp. gauge?
Old 08-03-2011, 07:15 PM   #20
Hubscrub
Cruzin
Hubscrub's Avatar
Originally Posted by CEE1NG_RED View Post
Water temp. gauge?
yes thats were you screw in the sensor or whatever it's called
Proverbs 3:5,6
Old 08-03-2011, 07:51 PM   #21
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
if worried about engine temps....you could also add an oil temp gauge to get a better view into your motors internal temp. Mine doesn't have one now, but will one day when I finish the interior.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-04-2011, 04:57 PM   #22
long69
my stock gauge sender is in the drivers head. i just added a mech. gauge (had it already)in the thermo housing. it gives me a nice indication of the status of the cooling process or the temp. of the water coming out of the radiator. after i have it there a while i'll move it to the more standard location the intake mani. right now it seems that the stock gauge reads right on.
long69 is offline   Reply With Quote
Old 06-22-2014, 02:33 PM   #23
gmhardwick66
I had mine in drivers side head and moved it to the passenger side head to allow for putting a second sending unit for my dual electric fans. When I placed temp gauge in passenger side head the temp reading was at least 30 degrees hotter compared to the reading when gauge was in drivers side head. Everything was exactly the same except temp reading. I am not positive but I am hoping the difference was due to the fact as the water circulates through engine and heads it heats up so when it gets to the gauge port on drivers side head it has soaked up a bunch of heat causing the difference in temp reading between the to ports. Can someone please tell me if this is correct or do I have another problem all together.
gmhardwick66 is offline   Reply With Quote
